Roman
What's your vin number sir?
Probably will end up there, but hoping for a chain store that's just up the rd
Share this post
Link to post
1 hour ago, tortron said:
Who supplies non tridon thermostats for commo 3.8s?
Current rather new one seems to be sticking closed
I just got a new tridon thermostat for a guy and it didnt work at all
  • Sad 1
Share this post
Link to post
Probably a stupid question but will it be ok if I try to recharge a fucked 10 year old motorbike battery?
I don't want to buy a new one because it'll most likely be sitting around for 12 months while I sort out shit on the bike but I'd like to be able to take it for a spin sometimes.
Cheers.
Share this post
Link to post
2 hours ago, johnnyfive said:
I think you're missing the obvious Barry answer of fitting your thermostat into the trash.
No fit a steel plate with a 16mm hole
Share this post
Link to post
Cheers.
Leaver the cap off and put a tea spoon of Epson salts in and top up with water if needed, if the plate dividers haven't broken down it might go
Share this post
Link to post
53 minutes ago, UTERUS said:
Also try banging another battery in parallel to get the charger to do its thing
Can also jolt it with an arc welder
Maybe look away when doing that
Share this post
Link to post
This works well but make sure its a DC welder
  • Haha 1
Share this post
Link to post
Not keen on the welder idea.
So like this, and should I leave the other battery on there or take it off after a couple of hours and continue to charge the little one?
Share this post
Link to post
Only long enough for the old battery to gain enough volts for he charger to.recognise it's a battery.
I am turning into lingor......
  • Haha 1
Share this post
Link to post
This works, but when the battery dies again it's pretty dead. In saying that I have a jdm battery that I can push start a car with after 12 months of sitting that had the Epson salt treatment.
Share this post
Link to post
Just tried the battery and it has a very little bit of charge. Popped the cover off and it's completely dry so I'll give it a drink tomorrow and try again. Will now google Epson salt to see wtf it is, doubt I'll have any.
Share this post
Link to post
18 hours ago, RUNAMUCK said:
I used open.end spanners once to bridge the two.batteries.
I did this to jump start a car a few years ago. Worked well, apart from the burn mark on the spanners after.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
