flyingbrick Posted March 27, 2022 Share Posted March 27, 2022 7 hours ago, 87creepin said: Does ctek rejuvenate mode really work? Or is it just a clever trick to fool us into buying a ctek charger then a new battery? It works extremely well. I have used it to bring numerous DEAD batteries back to life. The science is interesting and makes sense when ya look into it. 10/10 would bang again. 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted March 27, 2022 Share Posted March 27, 2022 56 minutes ago, UTERUS said: Fletch is bang on with charging advice, redarc stuff is really nice and safe but criminally expensive, keep an eye out for second hand stuff if you're not in a hurry. Run those panels in parallel, you'll want all the power you can get. I'd run a 24v winch from the main batteries and run a lithium house, have you got winch already? Unless you find a cheap PTO, that would be super sweet. PTO is out of the question unfortunately, there is way too much stuff happening in that area to fit it. I have bought a 12v winch already, just cos it was a good Warn and cheap. There was a 24v one that came up but it was Ironside branded which I think is sold through topmaq so I will a avoid that. Now that I know the alternator/solar chargers exist I will keep an eye out for one, it seems the go. 3 Quote Link to comment Share on other sites More sharing options...
NickJ Posted March 27, 2022 Share Posted March 27, 2022 Run the winch off the starting battery so that it gets the grunt of the alternator to help it out, if its a legit Warn you should be able to find a 24V motor on ebay. I have read about guys running 12V motors on 24V, just need to watch the temps and accept they will die sooner. Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted March 28, 2022 Share Posted March 28, 2022 Where's the best place to go price wise for automotive batteries? Surf has been getting a bit slow to start for awhile and finally decided not to start after work today. I need a NS70MF and a NS70LMF. Quote Link to comment Share on other sites More sharing options...
Nominal Posted March 28, 2022 Share Posted March 28, 2022 12 minutes ago, chasinthemirage said: Where's the best place to go price wise for automotive batteries? Surf has been getting a bit slow to start for awhile and finally decided not to start after work today. I need a NS70MF and a NS70LMF. @vk327 was potentially offering battery deals. 1 Quote Link to comment Share on other sites More sharing options...
JustHarry Posted March 29, 2022 Share Posted March 29, 2022 The ns70 are inexpensive. The ns70l is almost twice the price. Good luck 1 2 Quote Link to comment Share on other sites More sharing options...
Bling Posted March 29, 2022 Share Posted March 29, 2022 What's the deal with two batteries, and even different ones on a surf? Quote Link to comment Share on other sites More sharing options...
kws Posted March 29, 2022 Share Posted March 29, 2022 The L just indicates that the terminals are flipped, so negative is on the left instead of the right. Guess it's some real OCD shit, having the negatives mirrored. 2 Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted March 30, 2022 Share Posted March 30, 2022 1 hour ago, JustHarry said: The ns70 are inexpensive. The ns70l is almost twice the price. Good luck This is fake news 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 30, 2022 Share Posted March 30, 2022 "Oh well, I guess my car is gonna be positive ground from now on" 5 Quote Link to comment Share on other sites More sharing options...
kws Posted March 30, 2022 Share Posted March 30, 2022 Grind my gears when people get the wrong battery and you have to pull the cables real taught to make it fit. 6 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 30, 2022 Share Posted March 30, 2022 I had the wrong battery in my hilux for a while, but that was because I harvested it from the LPG Corolla when it got written off. Was always expecting the battery cables to snap at any moment Quote Link to comment Share on other sites More sharing options...
cletus Posted March 30, 2022 Share Posted March 30, 2022 44 minutes ago, kws said: Grind my gears when people get the wrong battery and you have to pull the cables real taught to make it fit. it's good, gives the electricity a straighter shot when the cables are tight, straight and short as possible 2 3 Quote Link to comment Share on other sites More sharing options...
Mof Posted March 30, 2022 Share Posted March 30, 2022 Stops the battery moving because the clamp hasn't been put back on 4 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 30, 2022 Share Posted March 30, 2022 There's supposed to be a clamp? 1 Quote Link to comment Share on other sites More sharing options...
JustHarry Posted March 30, 2022 Share Posted March 30, 2022 5 hours ago, Bling said: What's the deal with two batteries, and even different ones on a surf? Its so toyota could save 300ish* mm of positive battery cable from one side to the other. Across 11ty billion surfs/prados probbaly ads up to a pretty good saving. I'd imagine for the factory to jam 2 different batteries was probably less expensive that to ad the extra battery cable. Fuck the consumer *May be more or less that's a guess 2 Quote Link to comment Share on other sites More sharing options...
Bling Posted March 30, 2022 Share Posted March 30, 2022 Are they 24v or just need the cranking? For some reason I assumed 12v, but even stop start vehicles work on a single battery so perhaps not. Quote Link to comment Share on other sites More sharing options...
Mof Posted March 30, 2022 Share Posted March 30, 2022 1kz's like the cca's 3 Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 30, 2022 Share Posted March 30, 2022 7 hours ago, JustHarry said: The ns70 are inexpensive. The ns70l is almost twice the price. Good luck Someone's ripping you right off. They are the same price most of the time. 2 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted March 30, 2022 Share Posted March 30, 2022 Dual batteries was a cold weather option or something Had a surf with dual batteries running 12v Was great for parties in the wops could run the stereo all night without going flat 6 Quote Link to comment Share on other sites More sharing options...
