RUNAMUCK Posted March 17, 2022 Share Posted March 17, 2022 This was the video I saw. He indeed uses a stick welder. Quote Link to comment Share on other sites More sharing options...
tortron Posted March 17, 2022 Share Posted March 17, 2022 9 hours ago, SOHC said: Ramming high amps into your battery will just make the plates fuck out faster When charging normally When the battery is already fucked then crank it till it boils 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted March 17, 2022 Share Posted March 17, 2022 On 16/03/2022 at 19:25, ajg193 said: Doesn't logic dictate that if epsom salts actually made a shit battery really good then the factory would put it in? From my reading, it depends on the failure mode. If fails from over cycling (heavy discharge / recharge, the active material falls of the plates and shorts out plates (goes low impedance, depending on separator design). High current might clear the first wee shorts, and give more joy for a while. If over-discharged, left flat, undercharged, can sulfate (goes high impedance?). Possible that's what the epsom salts does, is rearrange the ions after that's happened? Of interest, I was going to measure between the plates, but couldn't get both probes in one holw. I did however get a reading as soon as the probes were in the fluid (from cell to cell), 2V, 2V, 2V, 2V, 1.2V So I know which end is faulty, just not which of those two cells, or which failure mode. I may make up some skinny probes to get a better measure. Oh, and Pulse charger: 6 Quote Link to comment Share on other sites More sharing options...
igor Posted March 17, 2022 Share Posted March 17, 2022 Should the one dodgy cell not give you the same low reading when paired with any other cell? Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 17, 2022 Share Posted March 17, 2022 A million dollars of equipment and skill to try and save a $120 battery. Sounds like oldschool 8 1 Quote Link to comment Share on other sites More sharing options...
h4nd Posted March 18, 2022 Share Posted March 18, 2022 Ackshually, have we made "Certified BARRY!" badges to be awarded? Quote Link to comment Share on other sites More sharing options...
Bling Posted March 18, 2022 Share Posted March 18, 2022 We don't like to encourage such things. Yours is in the mail 3 1 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted March 18, 2022 Share Posted March 18, 2022 8 hours ago, ajg193 said: A million dollars of equipment and skill to try and save a $120 battery. Sounds like oldschool Waste not, Want not M9 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted March 19, 2022 Share Posted March 19, 2022 CTEK gave it a go, didn't think it was sulphated, charged it, then thought it was toast. Epsom salts next. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted March 20, 2022 Share Posted March 20, 2022 https://recharge.net.nz/ 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted March 20, 2022 Share Posted March 20, 2022 3 minutes ago, RUNAMUCK said: https://recharge.net.nz/ I tried some of that on a sad case, didn't help. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted March 20, 2022 Share Posted March 20, 2022 60% of the time, it works every time........ 1 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 20, 2022 Share Posted March 20, 2022 Oil squeezed straight out the backside of a snake 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted March 20, 2022 Share Posted March 20, 2022 Their MSDS indicates it is just plain old fashioned phosphoric acid: https://recharge.net.nz/wp-content/themes/recharge/pdf/msd.pdf 2 1 Quote Link to comment Share on other sites More sharing options...
rusty360 Posted March 20, 2022 Share Posted March 20, 2022 21 hours ago, h4nd said: CTEK gave it a go, didn't think it was sulphated, charged it, then thought it was toast. Epsom salts next. I had one like the that Mr ctek didn't like it the first time, sorted it on the next start up thou. 1 Quote Link to comment Share on other sites More sharing options...
h4nd Posted March 20, 2022 Share Posted March 20, 2022 1 hour ago, rusty360 said: I had one like the that Mr ctek didn't like it the first time, sorted it on the next start up thou. I'll give it another try, (after 1/2 tablespoon of Epsom salts). But it's busy having a go at a motobatt AGM bike battery, which it seems to think is sulphated, so ... fingers crossed. 2 Quote Link to comment Share on other sites More sharing options...
datlow Posted March 21, 2022 Share Posted March 21, 2022 so google says brake dust cleaners are just "Thioglycolic acid" is there a cheap way of purchasing it, google wasnt very helpful Quote Link to comment Share on other sites More sharing options...
tortron Posted March 21, 2022 Share Posted March 21, 2022 Pacer 4L/$100 is cheaper than the lab stuff Quote Link to comment Share on other sites More sharing options...
kws Posted March 21, 2022 Share Posted March 21, 2022 Just noticed mitre10 has a 4l tin of crc brakleen on their site for $34, which doesn't seem like a bad deal. 1 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted March 21, 2022 Share Posted March 21, 2022 57 minutes ago, kws said: Just noticed mitre10 has a 4l tin of crc brakleen on their site for $34, which doesn't seem like a bad deal. If only it was available 1 Quote Link to comment Share on other sites More sharing options...
