tortron Posted June 13, 2021 Share Posted June 13, 2021 And replace them every stage? Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 15, 2021 Share Posted June 15, 2021 On 30/05/2021 at 12:55, Nominal said: Where can I get a decent set of jumper leads? Ones with actual bolted on clamps, not shitty pressed/crimped supercheat style. Ordered some of these Projecta 1000A clamps. Kind of spendy but seem grunty enough. Now to get some cables. 4 Quote Link to comment Share on other sites More sharing options...
SOHC Posted June 15, 2021 Share Posted June 15, 2021 3 hours ago, Nominal said: Ordered some of these Projecta 1000A clamps. Kind of spendy but seem grunty enough. Now to get some cables. Get some 19 mm2 cable 1 Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 15, 2021 Share Posted June 15, 2021 25mm double insulated flex is most commonly used. https://www.trademe.co.nz/3132796229 1 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 15, 2021 Share Posted June 15, 2021 40 minutes ago, UTERUS said: 25mm double insulated flex is most commonly used. https://www.trademe.co.nz/3132796229 Would a normal electrical wholesaler have this sort of thing, and be able to crimp a lug on the end? Quote Link to comment Share on other sites More sharing options...
datlow Posted June 15, 2021 Share Posted June 15, 2021 Should do, or try global welding supply’s etc Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 15, 2021 Share Posted June 15, 2021 53 minutes ago, Nominal said: Would a normal electrical wholesaler have this sort of thing, and be able to crimp a lug on the end? They'll have the cable and lugs, but won't crimp them for you. Whatever you do, don't be tempted to solder them. You could try bribe an auto sparky to crimp them? 2 Quote Link to comment Share on other sites More sharing options...
chris r Posted June 16, 2021 Share Posted June 16, 2021 3 hours ago, UTERUS said: 25mm double insulated flex is most commonly used. https://www.trademe.co.nz/3132796229 R33 skidlines have battery in boot and decent sized (25 or 35mm) cable. Cheap from pap if you don't value your time Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 16, 2021 Share Posted June 16, 2021 2 minutes ago, chris r said: R33 skidlines have battery in boot and decent sized (25 or 35mm) cable. Cheap from pap if you don't value your time Is that a factory thing? I thought some bogan had relocated mine into the trunk? Quote Link to comment Share on other sites More sharing options...
chris r Posted June 16, 2021 Share Posted June 16, 2021 27 minutes ago, RUNAMUCK said: Is that a factory thing? I thought some bogan had relocated mine into the trunk? It's factory. I've robbed a few of them for the cables 2 Quote Link to comment Share on other sites More sharing options...
NickJ Posted June 16, 2021 Share Posted June 16, 2021 10 hours ago, Nominal said: Would a normal electrical wholesaler have this sort of thing, and be able to crimp a lug on the end? +1 for decent welding supplier and they will be able to crimp the lugs for you. They have the hard wearing double insulation cable, most electrical places don't. 1 Quote Link to comment Share on other sites More sharing options...
NickJ Posted June 17, 2021 Share Posted June 17, 2021 Getting my hands on ~60m of scrap 35x65 rhs with the plan to build a chassis dolly/rotisserie for the Datsun. I want to be able to strip the suspension and still push it in and out of the workshop for the dusty/muck work. Cos i'm a cheap c&*t, whats the most cost effective solution to getting wheels under it? While i'd like to have large locking castor wheels, that would far exceed the current investment of $0. Best idea I have come up with so far is a set of tyre dollys because they will be useful once the resto is complete. 1 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 17, 2021 Share Posted June 17, 2021 28 minutes ago, NickJ said: Getting my hands on ~60m of scrap 35x65 rhs with the plan to build a chassis dolly/rotisserie for the Datsun. I want to be able to strip the suspension and still push it in and out of the workshop for the dusty/muck work. Cos i'm a cheap c&*t, whats the most cost effective solution to getting wheels under it? While i'd like to have large locking castor wheels, that would far exceed the current investment of $0. Best idea I have come up with so far is a set of tyre dollys because they will be useful once the resto is complete. I just bought 3 castors rated at 50kg each from bunnings for $30ish. They had bigger ones there too 2 Quote Link to comment Share on other sites More sharing options...
NickJ Posted June 17, 2021 Share Posted June 17, 2021 1 minute ago, bigfoot said: I just bought 3 castors rated at 50kg each from bunnings for $30ish. They had bigger ones there too Estimating the body to be ~300kg so will need 100kg+ castors to be safe which are $50 + area. Getting up to that price range I figure the wheel dollys leave me with options later on. Quote Link to comment Share on other sites More sharing options...
tortron Posted June 17, 2021 Share Posted June 17, 2021 https://www.supercheapauto.co.nz/p/sca-jockey-wheel-6-standard/523111.html?cgid=SCN01041201#start=1 1 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 17, 2021 Share Posted June 17, 2021 5 minutes ago, NickJ said: Estimating the body to be ~300kg so will need 100kg+ castors to be safe which are $50 + area. Getting up to that price range I figure the wheel dollys leave me with options later on. https://www.bunnings.co.nz/move-it-125mm-100kg-black-rubber-swivel-plate-castor-with-brake_p3940326 I got mine for an engine stand, they didn't have these ones when I got mine. 3 on each end should be heaps 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted June 17, 2021 Share Posted June 17, 2021 That's a good price Quote Link to comment Share on other sites More sharing options...
NickJ Posted June 17, 2021 Share Posted June 17, 2021 6 minutes ago, bigfoot said: https://www.bunnings.co.nz/move-it-125mm-100kg-black-rubber-swivel-plate-castor-with-brake_p3940326 I got mine for an engine stand, they didn't have these ones when I got mine. 3 on each end should be heaps Shit, they are way cheaper than the last time I looked! Might grab a set for the table saw as a test run 9 minutes ago, tortron said: https://www.supercheapauto.co.nz/p/sca-jockey-wheel-6-standard/523111.html?cgid=SCN01041201#start=1 Thats actually not a bad idea instead of locking castors Quote Link to comment Share on other sites More sharing options...
cletus Posted June 18, 2021 Share Posted June 18, 2021 Machinery house has big industrial caster wheels, cant remember how much exactly but they were the cheapest big ones I could find . And they have brakes 5 Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 19, 2021 Share Posted June 19, 2021 So, Pajero's FInally bodged another fuel pump into this heap today but still no go. Fump is running OK - fuel flows out the return line while cranking. It stopped running just a few hundred metres from home a couple of weeks back with no drama, 1/2 power for a bit, then recovered, then no power Anything else easy to check? Quote Link to comment Share on other sites More sharing options...
