kicker Posted March 1, 2020 Share Posted March 1, 2020 Was the tube made pre 1965? 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 1, 2020 Share Posted March 1, 2020 11 hours ago, kicker said: Was the tube made pre 1965? They have been making this tube size since WW1 2 Quote Link to comment Share on other sites More sharing options...
Valiant Posted March 2, 2020 Share Posted March 2, 2020 AFWE. Did you call them? Quote Link to comment Share on other sites More sharing options...
Bling Posted March 2, 2020 Share Posted March 2, 2020 On 29/02/2020 at 07:36, kpr said: worth seeing if toyota has them. 3AU one on it's way from Japan, cheers. About the same price as that one in Aussie, sans o-rings, but I have those so not an issue. Only reason it didn't occur to me to check with them first was that all of cooling system parts I asked for were NLA. So I ended up getting waterpump and all hoses etc from RockAuto. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 4, 2020 Share Posted March 4, 2020 I need to change the intank fuel pump on a 04 mitsi colt but I cannot get the rear seats to fold up, I am going to cut the rails off with the grinder after lunch Quote Link to comment Share on other sites More sharing options...
tortron Posted March 4, 2020 Share Posted March 4, 2020 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 I have cut it apart with a knife and smashed the release things off with a hammer, just unbolting the frame now after ripping everything off Quote Link to comment Share on other sites More sharing options...
tortron Posted March 5, 2020 Share Posted March 5, 2020 seems reasonable Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 I am going to have to take to the rails with a grinder, everything is full of sand from dogs, needs a new rear seat anyway 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 Fuck this seat it’s still in 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted March 5, 2020 Share Posted March 5, 2020 Try petrol and a match 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 My ford v8 crab type distributor cap has 2 holes burnt in the sides onsite each other, its a new cap, I think because its out slightly on its dimensions the rotor had collided with one of the contacts and twisted its end causing it to point about 5mm off on an angle causing the spark to jump? Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 Would a powerful coil also cause this? Quote Link to comment Share on other sites More sharing options...
Nominal Posted March 5, 2020 Share Posted March 5, 2020 8 hours ago, SOHC said: Would a powerful coil also cause this? Probably a crappy aftermarket cap? Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 2 minutes ago, Nominal said: Probably a crappy aftermarket cap? Yes it’s a bob drake cap, I got one of his distributor rotors and it’s going to need serous work to get it to fit Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 5, 2020 Share Posted March 5, 2020 The holes are inbtween 4&5 and 6&8 like that cap was extra shit in that place, I need the car for Sunday and every other cap I have is shit in some way Quote Link to comment Share on other sites More sharing options...
Nominal Posted March 5, 2020 Share Posted March 5, 2020 Is it stopping it running? Bit of JB Weld over the top? Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted March 5, 2020 Share Posted March 5, 2020 If JB weld or something will hold the dirt out, do it. I once replaced the top of a model A distributor with a popsical stick with wires shoved through little holes. Based that one on stories on the internet. There was a video of someone doing it somewhere but i can't find it now /Ling 2 Quote Link to comment Share on other sites More sharing options...
yetchh Posted March 5, 2020 Share Posted March 5, 2020 1 hour ago, Ghostchips said: If JB weld or something will hold the dirt out, do it. I once replaced the top of a model A distributor with a popsical stick with wires shoved through little holes. Based that one on stories on the internet. There was a video of someone doing it somewhere but i can't find it now /Ling Macgyver.. Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 6, 2020 Share Posted March 6, 2020 It still runs sweet even with a smashed rotor and 2 holes in the cap but I think it makes it hard to start, I have some Jb weld stuff but I think it contains alloy, I am wondering if the Pertonix flamethrower coil is too much fot this shitty repro cap, I need to find a Mallory one Quote Link to comment Share on other sites More sharing options...
