SOHC Posted June 27, 2019 Share Posted June 27, 2019 6 minutes ago, tortron said: They have a TradeMe account called ironmaiden, store in Manukau I think oh yes thats steel cuts, useless, grumpy 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 2, 2019 Share Posted July 2, 2019 Anyone have a carb for this and a distributor drive? It’s a 2.2, and needs the straight drive bit for the dizzy Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 2, 2019 Share Posted July 2, 2019 If you get stuck for carbs i have random ones you could pick through. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 4, 2019 Share Posted July 4, 2019 Question one, How strong is tje diff in a 'tezza? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 4, 2019 Share Posted July 4, 2019 Question two, AN/ dash fittings/braided hose, how do the numbers relate to a size in a real work measurement? I'm looking at cheap treasures from the Orient. But those numbers don't actually mean anything to me? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 4, 2019 Share Posted July 4, 2019 29 minutes ago, RUNAMUCK said: Question one, How strong is tje diff in a 'tezza? From skimming forums for next to useless info a few years ago suggests about 300KW if you're not too much of a rough bastard. They're cheap enough though so break one and try again. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 4, 2019 Share Posted July 4, 2019 A dash is a 1/16th I think? So -4 AN is 1/4" I think 2 Quote Link to comment Share on other sites More sharing options...
NickJ Posted July 4, 2019 Share Posted July 4, 2019 38 minutes ago, RUNAMUCK said: Question two, AN/ dash fittings/braided hose, how do the numbers relate to a size in a real work measurement? I'm looking at cheap treasures from the Orient. But those numbers don't actually mean anything to me? Workmate just brought a stack of chinesium AN fittings for an efi conversion, macaroni elbows would have been a superior material choice..... 7 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 4, 2019 Share Posted July 4, 2019 So avoid AliExpress? It's hard to know what brand to go for for such an item as there's so many shit ones that look identical in the pics. Quote Link to comment Share on other sites More sharing options...
Nominal Posted July 4, 2019 Share Posted July 4, 2019 34 minutes ago, Yowzer said: So avoid AliExpress? It's hard to know what brand to go for for such an item as there's so many shit ones that look identical in the pics. Some things are probably better bought from a legit supplier. 3 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 4, 2019 Share Posted July 4, 2019 Yep, when it's carrying pressurized fuel or oil, I'd rather pay more for quality. 3 Quote Link to comment Share on other sites More sharing options...
NickJ Posted July 4, 2019 Share Posted July 4, 2019 1 hour ago, Yowzer said: So avoid AliExpress? It's hard to know what brand to go for for such an item as there's so many shit ones that look identical in the pics. Yes/No, I actually thought it would be a good way to size the system for cheap and then buy legit ones. The tapered threads on the Ali ones were that terrible, I doubt they would make a seal of any confidence 2 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 4, 2019 Share Posted July 4, 2019 I'm sure with a bit of digging we could find a good supplier on Ali. After all most of the legit brands probably come from there anyway. 2 Quote Link to comment Share on other sites More sharing options...
Roman Posted July 5, 2019 Author Share Posted July 5, 2019 I went down that road and bought a couple of different styles as I figured some would be shit. The ones that are "square cut" like, they are drilled from one side and drilled from the other. Avoid. Most of them had a small piece of swarf still stuck to it internally! Went straight in the bin. These ones were good (I've used them with fuel and oil for several years, including a lot of do ups and undos with no issues at all)https://www.aliexpress.com/item/32741180690.html?spm=a2g0s.9042311.0.0.27424c4d670JXqhttps://www.aliexpress.com/item/32718466578.html?spm=a2g0s.9042311.0.0.27424c4d670JXq This style, avoid:https://www.aliexpress.com/item/32743291389.html?spm=a2g0s.9042311.0.0.27424c4d4HvP3k I reckon the biggest cause of fuckups with AN lines though is putting them together improperly. I found putting masking tape around the outside then using a cut off wheel gave the best results. But need to clean a bunch of crap out of the line afterwards (But need to whichever method you use) 4 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 16, 2019 Share Posted July 16, 2019 Can someone help me find a LH mirror for a 1999 Toyota corrola hatch GLX 4A? I cannot find one where do I start? Quote Link to comment Share on other sites More sharing options...
tortron Posted July 16, 2019 Share Posted July 16, 2019 https://www.ebay.com.au/itm/DOOR-MIRROR-95-00-TOYOTA-COROLLA-E110-AE111-112-AE113-CE110-EE110-EE115-ELECTRIC/322910425234?hash=item4b2ef61092%3Ag%3A5CoAAOSwLdJcY2Ck&fits=Year%3A1999|Model%3ACorolla|Make%3AToyota Worth more than the car? 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 16, 2019 Share Posted July 16, 2019 1 hour ago, SOHC said: Can someone help me find a LH mirror for a 1999 Toyota corrola hatch GLX 4A? I cannot find one where do I start? Parts world or equivalent should be able to track one down. 1 Quote Link to comment Share on other sites More sharing options...
Mof Posted July 27, 2019 Share Posted July 27, 2019 Hello gents Is there a way to reduce the power steering assistance? I feel it's just too light. Cheers Quote Link to comment Share on other sites More sharing options...
tortron Posted July 27, 2019 Share Posted July 27, 2019 Yes, you can get pressure reducing kits for some Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 28, 2019 Share Posted July 28, 2019 I had a triumph PI someone had brazed in a T into one of the pressure lines and then brazed in a return to the tank on the pump to bleed off pressure 1 Quote Link to comment Share on other sites More sharing options...
