Roman
17 minutes ago, tortron said:
Is that in the club mag?
Maybe il inject my 1276 and go full Barry in the diyinjection thread
Also welded aluminium to the intake manifold. Wat
Originated from the ChCh club I think.
  • Replies 6.1k
1 minute ago, Yowzer said:
Hell yeah. You better be running it off an Arduino, using components raided from old DVD players and the likes
I think you could use a single injector and screw it in where the jet goes underneath the SU
Maybe I should make a few for the guys that don't want to use a sidedraught style hidden injector
I need to test the fuel pressure on my BMW to see if the FPR is working properly, but getting to the fuel hoses at the rail is a real pain. Is there anything stopping me from testing the fuel pressure down at the fuel filter under the car?
So I messed around with that kick press a few pages back.
2mm seems a bit too much for it (without bolting it to the floor and kicking the crap out of it) but 1mm was passable
IMG_20190529_161748.thumb.jpg.79f461432390dcc2754e8a72664dbeab.jpgIMG_20190529_161803.thumb.jpg.ca6dc67d6674ef8604102ab0b2e5a6fa.jpg
probably the kick wasn't originally mounted that low and was bolted direct to the holes in the frame.
Might get a full length male die plate made and cut it to fingers. 800mm might take a few kicks
Should be fine. Don't they have a screw fitting on the rail for hooking a gauge up?
