tortron Posted April 25, 2019 Share Posted April 25, 2019 Quote Link to comment Share on other sites More sharing options...
Get it done Posted April 25, 2019 Share Posted April 25, 2019 Does anyone have plans for a home built car rotisserie please? Quote Link to comment Share on other sites More sharing options...
tortron Posted April 25, 2019 Share Posted April 25, 2019 5 minutes ago, Get it done said: Does anyone have plans for a home built car rotisserie please? I have one of these Its a little more basic than the sold ones. Two hoops with a 2m ID And they sit on a large piece of C channel and roll on some boat trailer rollers. Weld some mounting tabs around the inside edge and you can make jigs to hold onto anything. Good for attaching to say suspension mounting points rather than rusted out bumper mounts. Im working on a foot brake ATM. Maybe just an additional braked caster wheel to run against the outside of the hoop. I'll probably be done in about 6 months if you want to borrow 3 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted April 25, 2019 Share Posted April 25, 2019 Great benefit of this type is you can just hang it against a wall. The double engine stand type take up quite a bit of room. You can also get some steel rims and weld some J shaped steel arms on them and just push the car in its side of you have the option To leave the suspension In Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 6, 2019 Share Posted May 6, 2019 We were out in the Holden on Saturday, got about 5km away from home and heard a weird noise, sounded a bit like a speedo cable tick from inside the car. Stopped and had a look under the hood, then decided to drive home stat. Idles OK and just driveable but much more than light throttle results in misfiring. Any guesses on what's wrong, place bets now :0 Going to start investigating now. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 6, 2019 Share Posted May 6, 2019 Valvetrain. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted May 6, 2019 Share Posted May 6, 2019 That is the sound of fucked 4 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 6, 2019 Share Posted May 6, 2019 1 minute ago, kyteler said: Valvetrain. Yes, likely. Maybe a dud lifter then ??? 1 minute ago, Yowzer said: That is the sound of fucked Time for a 5M swap? Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 6, 2019 Share Posted May 6, 2019 You want it better, not worse. 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 6, 2019 Share Posted May 6, 2019 Also, rocker arms have probably just spontaneously loosened. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 6, 2019 Share Posted May 6, 2019 Compressions OK 1,2,3,4,6 at ~180psi #5 is down about 140psi........ Quote Link to comment Share on other sites More sharing options...
Popular Post Nominal Posted May 6, 2019 Popular Post Share Posted May 6, 2019 37 minutes ago, kyteler said: Also, rocker arms have probably just spontaneously loosened. Loose as Al's Mum. 11 2 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 6, 2019 Share Posted May 6, 2019 Idles like a well oiled sewing machine.... Need a new rocker cover gasket now though. 4 1 Quote Link to comment Share on other sites More sharing options...
scooters Posted May 6, 2019 Share Posted May 6, 2019 Just had a flash back It was sounding exactly like the seconds before when your car blows up from damage in GTA2 game (birds eye one) 2 Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 6, 2019 Share Posted May 6, 2019 8 hours ago, Nominal said: Loose as Al's Mum. Bingo. What do I win? 2 Quote Link to comment Share on other sites More sharing options...
Popular Post tortron Posted May 10, 2019 Popular Post Share Posted May 10, 2019 Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass 9 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 10, 2019 Share Posted May 10, 2019 2 hours ago, tortron said: Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass Imagine how much their bottle rental from BOC would cost! 3 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted May 11, 2019 Share Posted May 11, 2019 The thickest I have cut is 300mm, hardest part is blowing through for the start, I had to drill a couple of holes to start from for the internal holes Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 11, 2019 Share Posted May 11, 2019 10 hours ago, tortron said: Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass Surely it be easier to use a big guillotine.. Quote Link to comment Share on other sites More sharing options...
tortron Posted May 11, 2019 Share Posted May 11, 2019 Apprentice and hacksaw 3 1 Quote Link to comment Share on other sites More sharing options...
