ajg193 Posted September 28, 2018 Share Posted September 28, 2018 Pretty much, your kidneys just filter out the excess magnesium as the screw corrodes. Should theoretically make for nicer surgery and whatnot where you don't need to go back in a year or two later to have the annoying screws removed. One surgery and 16 weeks later you are as good as new. 5 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted September 28, 2018 Share Posted September 28, 2018 I prefer my surgical screws to be nickel plated Quote Link to comment Share on other sites More sharing options...
NickJ Posted September 29, 2018 Share Posted September 29, 2018 On 28/09/2018 at 17:00, ajg193 said: Well after about 12 weeks it wouldn't really matter anyway as the screws biodegrade and encourage bone growth in their place Thats cool, I was wondering what function a reactive metal had as an implant, very nice Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 29, 2018 Share Posted September 29, 2018 Had an interesting conversation with my spine surgeon around what the torque settings are for the hardware he fitted during my spinal fusion....... Said no one had ever asked, i asked again he kinda went pale and admitted they were "pretty tight" one more thing to worry about, he had me on 3 monthly xrays after one shifted during a big sneeze. 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 29, 2018 Share Posted September 29, 2018 They should use suture as tie wire Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 2, 2018 Share Posted October 2, 2018 Anyone built a sandblasting setup at home? Quote Link to comment Share on other sites More sharing options...
yetchh Posted October 2, 2018 Share Posted October 2, 2018 No but I've been eyeing up the water blaster attachments for sand blasting, should be much cleaner.. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted October 2, 2018 Share Posted October 2, 2018 Maybe @EURON8 made one a while ago? I have soda blasted before with a piece of tube and an air pistol. Worked well. 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 4, 2018 Share Posted October 4, 2018 2 Quote Link to comment Share on other sites More sharing options...
datlow Posted October 4, 2018 Share Posted October 4, 2018 On 03/10/2018 at 10:21, yetchh said: No but I've been eyeing up the water blaster attachments for sand blasting, should be much cleaner.. i ali expressed one the other day, hoping it will work/wont have to worry about running out of air constantly /just have to worry about flash rusting after 1 Quote Link to comment Share on other sites More sharing options...
datlow Posted October 4, 2018 Share Posted October 4, 2018 speaking of metal in bodys, my boy just got his taken out in august, the screws were far longer than i had envisaged asked the surgeon why they take the plate and screws out etc, he just said its better etc (no real firm reason) wifes been crook on and off this year with whack blood samples been to a few specialists, latest one reckons because she still has metal in her back (scoliosis rods) its not uncommon for the body to react to the metal after about 15yrs, theyve been in 20! 1 Quote Link to comment Share on other sites More sharing options...
Adoom Posted October 4, 2018 Share Posted October 4, 2018 20 minutes ago, datlow said: speaking of metal in bodys, my boy just got his taken out in august, the screws were far longer than i had envisaged asked the surgeon why they take the plate and screws out etc, he just said its better etc (no real firm reason) wifes been crook on and off this year with whack blood samples been to a few specialists, latest one reckons because she still has metal in her back (scoliosis rods) its not uncommon for the body to react to the metal after about 15yrs, theyve been in 20! I've still got a rod in my leg. Doc told me that if there is high probability I would break the same leg again, it would be removed, otherwise they leave it in. Reasoning was that if the rod bends at the break, it makes it rather hard to get out. 1 1 Quote Link to comment Share on other sites More sharing options...
kws Posted October 12, 2018 Share Posted October 12, 2018 So my Mini failed its rego inspection on a rear brake imbalance, with the LH side only doing 10% of the work. obviously not good, and ill strip it down and see whats up, but what im stuck with, is without rollers, can anyone think of a simple way for someone at home to test for an imbalance? I'm guessing no, but it's going to be a pain to take it down to VTNZ again to see if it passes or not. Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 12, 2018 Share Posted October 12, 2018 Handbrake test on gravel might give you an indication? 3 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted October 12, 2018 Share Posted October 12, 2018 Familiar with any workshops who may be prepared to loan you their brake meter for a box of beer? Quote Link to comment Share on other sites More sharing options...
NickJ Posted October 12, 2018 Share Posted October 12, 2018 42 minutes ago, kws said: So my Mini failed its rego inspection on a rear brake imbalance, with the LH side only doing 10% of the work. obviously not good, and ill strip it down and see whats up, but what im stuck with, is without rollers, can anyone think of a simple way for someone at home to test for an imbalance? I'm guessing no, but it's going to be a pain to take it down to VTNZ again to see if it passes or not. This is the constant pain with the Niva, I can get it pretty close by feel setting the brakes on stands at home, then heavy braking on a quiet road to be sure, often one side just needs a tad more to get it right and the wof guys seem to understand. It does suck though and is my main motivation to set up rear discs! 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 12, 2018 Share Posted October 12, 2018 Throw in some new shoes and cylinders, scuff the drums and set them up as you would any other drums. They should work fine then. You could always use a torque wrench to find the breakaway torque with a known load on the pedal? (but that would probably require making some sort of a jig up) 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 12, 2018 Share Posted October 12, 2018 Standstill burnouts will even up the rears pretty quick 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 12, 2018 Share Posted October 12, 2018 1 minute ago, Yowzer said: Standstill burnouts will even up the rears pretty quick Mini is fwd? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 12, 2018 Share Posted October 12, 2018 Scrap it 4 3 1 Quote Link to comment Share on other sites More sharing options...
