Yowzer Posted July 12, 2018 Share Posted July 12, 2018 You can buy a 100A rectifier diode for like $10. Parallel stacking diodes doesn't work, they don't evenly share current so they fry themselves one at a time. 1 Quote Link to comment Share on other sites More sharing options...
Willdat? Posted July 12, 2018 Share Posted July 12, 2018 11 hours ago, Bling said: I might be a bit late, but make some at school? I can take a photo of mine if wanted. I didn't make them, but they are solid as fuuuuck. I'd trust them over the ones you buy with cast hooks. Would be keen to see some photos! Quote Link to comment Share on other sites More sharing options...
Bling Posted July 12, 2018 Share Posted July 12, 2018 One hook slides over the thread, the other is used for clamping. with a tube for spacing as required. Go pretty well, bolts might need replacing in 30 years or so, apart from that, all good. 2 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 13, 2018 Share Posted July 13, 2018 2 hours ago, Firetruck said: You can buy a 100A rectifier diode for like $10. Parallel stacking diodes doesn't work, they don't evenly share current so they fry themselves one at a time. Tell me.Moar about these diodes? I'm thinking I'll go.for one of.those pocket sized jump.start power banks for a cell. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 13, 2018 Share Posted July 13, 2018 AliExpress for all your electronic needs Quote Link to comment Share on other sites More sharing options...
chris r Posted July 13, 2018 Share Posted July 13, 2018 Just usr a relay tbh. Diodes will have small drop in voltage across them which could potentially cause charging issues Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 13, 2018 Share Posted July 13, 2018 26 minutes ago, RUNAMUCK said: Tell me.Moar about these diodes? I'm thinking I'll go.for one of.those pocket sized jump.start power banks for a cell. Just use a relay yo. Also I'm being pedantic but a cell is what multiple of make up a battery. There are 6 X 2V cells in a car battery. Xox 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted July 13, 2018 Share Posted July 13, 2018 On 6/26/2018 at 22:31, Willdat? said: Spring compressors - not something I need often, but keen to own. Where's the sweet spot of cheap/not shit? i have a set. have used lots with out failing. But the issue i have with them is that they have a quite fine thread on them, as a result they are slow and can be very hard to use when you dont have much room to swing a ratchet. a courser thread would be faster to compress making them easier to use. They are the double claw type but most of the time only one of the two is being used. mine also have 1/2 inch fitting so duga duga duga My 2c 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 13, 2018 Share Posted July 13, 2018 I struggle to imagine these handling 10 amps on their own https://www.aliexpress.com/item/10-Pcs-Active-Components-Diodes-10A10-Rectifier-Diode-10A-1000V-Charging-Diode-AMP-Silicone-Rectifiers/32841145533.html Wonder how long it would be until they pop? Can't be a continuous rating.. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 13, 2018 Share Posted July 13, 2018 10 amps is fuck all. That's only 10KW at max volts. Easy as. Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 13, 2018 Share Posted July 13, 2018 3 hours ago, rustisize said: I struggle to imagine these handling 10 amps on their own https://www.aliexpress.com/item/10-Pcs-Active-Components-Diodes-10A10-Rectifier-Diode-10A-1000V-Charging-Diode-AMP-Silicone-Rectifiers/32841145533.html Wonder how long it would be until they pop? Can't be a continuous rating.. What are you making? Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 13, 2018 Share Posted July 13, 2018 35 minutes ago, SOHC said: What are you making? Nothing yet but i thought of a magneto charger, in the absence of a generator. 2 Quote Link to comment Share on other sites More sharing options...
h4nd Posted July 14, 2018 Share Posted July 14, 2018 They'll do 10A, but they'll run hot. Diodes are cheap, get big-uns. Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 19, 2018 Share Posted July 19, 2018 I got some new water pumps and they came with gaskets, I fitted the gasket with silicon on both sides but water is seeping through the gasket paper and coming out its edge. I thought this is really shitty, its .002" paper and seems to be the asbestos type Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 19, 2018 Share Posted July 19, 2018 Douse the edges with shellac? 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted July 19, 2018 Share Posted July 19, 2018 I want this but can't justify it when my cars don't need any major work on them...... Single phase portable hoist. Also good motorcycle table https://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/jacks/listing-1702879063.htm?rsqid=a62f40473fae4fe0909526744afdab01 Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 19, 2018 Share Posted July 19, 2018 That's a sweet bit of kit but 2K? You could buy an actual hoist for that. 1 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted July 19, 2018 Share Posted July 19, 2018 No good for dropping a gearbag or diff out 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted July 19, 2018 Share Posted July 19, 2018 But it's portibke KY, and if you can't fit a hoist it's probably ok Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 20, 2018 Share Posted July 20, 2018 On 7/19/2018 at 19:56, rustisize said: Douse the edges with shellac? it seems to b loosing a spoon full of water every 12 hours, they are comming out and going in the bin and they will be replaced with KLINGER Statite paper. Quote Link to comment Share on other sites More sharing options...
