Roman
  • Replies 6.1k
11 hours ago, Bling said:
I might be a bit late, but make some at school? I can take a photo of mine if wanted. I didn't make them, but they are solid as fuuuuck. I'd trust them over the ones you buy with cast hooks.
Would be keen to see some photos!
2 hours ago, Firetruck said:
You can buy a 100A rectifier diode for like $10.
Parallel stacking diodes doesn't work, they don't evenly share current so they fry themselves one at a time.
Tell me.Moar about these diodes?
I'm thinking I'll go.for one of.those pocket sized jump.start power banks for a cell.
Just use a relay yo.
Also I'm being pedantic but a cell is what multiple of make up a battery.
There are 6 X 2V cells in a car battery.
Xox
On 6/26/2018 at 22:31, Willdat? said:
Spring compressors - not something I need often, but keen to own. Where's the sweet spot of cheap/not shit?
i have a set. have used lots with out failing.
But the issue i have with them is that they have a quite fine thread on them, as a result they are slow and can be very hard to use when you dont have much room to swing a ratchet. a courser thread would be faster to compress making them easier to use.
They are the double claw type but most of the time only one of the two is being used.
mine also have 1/2 inch fitting so duga duga duga
My 2c
I got some new water pumps and they came with gaskets, I fitted the gasket with silicon on both sides but water is seeping through the gasket paper and coming out its edge.
I thought this is really shitty, its .002" paper and seems to be the asbestos type
On 7/19/2018 at 19:56, rustisize said:
Douse the edges with shellac?
it seems to b loosing a spoon full of water every 12 hours, they are comming out and going in the bin and they will be replaced with KLINGER Statite paper.
