Testament Posted November 20, 2017 Share Posted November 20, 2017 49 minutes ago, igor said: pics please don't have any showing whats inside I can easily find but its a real pickapart special. rover bw35 trans, old Datsun transfer case, hilux diffs, seats from a Honda city and yes that's one bank of the exhaust going across the bottom of the windscreen to the other side because there is no room past the steering box when it was going it went great/goes hard for what it is 3 Quote Link to comment Share on other sites More sharing options...
Nominal Posted November 20, 2017 Share Posted November 20, 2017 54 minutes ago, Roman said: The heaviest car that I've found that still uses a disc operated handbrake (so handbrake built into caliper rather than seperate drum) is an SW20 MR2 or I think an FD RX7 maybe had similar. I'm in a similar boat as my rear brakes are too powerful/big and I have to turn them almost completely off using a proportioning valve. I think I'm going to check out AW11 MR2 rear calipers or maybe AE82 etc. I saw a fairly modern volvo something something that had a really nice light looking alloy caliper on the rear with handbrake attached. I've used 200SX ones on my project. 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 20, 2017 Share Posted November 20, 2017 Actually many nissans have rear disc including handbrake. I think I have a complete rear set up from a u12 bluey you could have for a box. 2 Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted November 20, 2017 Share Posted November 20, 2017 9 minutes ago, RUNAMUCK said: Actually many nissans have rear disc including handbrake. I think I have a complete rear set up from a u12 bluey you could have for a box. if not, i will have either P11 Primera orAE82/92 corolla down the road in Timaru Quote Link to comment Share on other sites More sharing options...
Roman Posted November 20, 2017 Author Share Posted November 20, 2017 That looks pretty good, do you know what sized disc it takes? Are they hard to get? Quote Link to comment Share on other sites More sharing options...
Testament Posted November 20, 2017 Share Posted November 20, 2017 galant/fto is another 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted November 20, 2017 Share Posted November 20, 2017 1 hour ago, Roman said: That looks pretty good, do you know what sized disc it takes? Are they hard to get? I think it's a Mazda 626/Telstar front disc. About 270mm dia and 10mm thick. I've had the calipers for ages so I'm not sure what the supply is like. Quote Link to comment Share on other sites More sharing options...
Transom Posted November 20, 2017 Share Posted November 20, 2017 Nissan Maxima rear calipers with handbrake included used to be the go for hilux rear disc conversions Quote Link to comment Share on other sites More sharing options...
NickJ Posted November 20, 2017 Share Posted November 20, 2017 270mm is the diameter i'm working with, going to check out Bart's supply if he can dig them out, but the other options all sound findable Quote Link to comment Share on other sites More sharing options...
RevDWC Posted November 20, 2017 Share Posted November 20, 2017 Do you know if the mounting on the Niva diff is the same as the sedan one? Quote Link to comment Share on other sites More sharing options...
NickJ Posted November 20, 2017 Share Posted November 20, 2017 9 minutes ago, RevDWC said: Do you know if the mounting on the Niva diff is the same as the sedan one? flange is the same, but the bearings are different from memory (due to axle diameter) Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 20, 2017 Share Posted November 20, 2017 It's a Niva. You should be happy to have any brakes at all. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 20, 2017 Share Posted November 20, 2017 Mazda 3/6/5s all have disc handbrakes 1 Quote Link to comment Share on other sites More sharing options...
NickJ Posted November 20, 2017 Share Posted November 20, 2017 1 hour ago, ajg193 said: It's a Niva. You should be happy to have any brakes at all. only brakes on a Lada is breaks 3 Quote Link to comment Share on other sites More sharing options...
Roman Posted November 20, 2017 Author Share Posted November 20, 2017 You only need brakes if it goes 7 Quote Link to comment Share on other sites More sharing options...
NickJ Posted November 20, 2017 Share Posted November 20, 2017 8 hours ago, Roman said: You only need brakes if it goes Ouch! but I bet you'd be proud of the fuel economy 1 1 Quote Link to comment Share on other sites More sharing options...
igor Posted November 20, 2017 Share Posted November 20, 2017 11 hours ago, ajg193 said: It's a Niva. You should be happy to have any brakes at all. Like old Landrovers in that respect then? Quote Link to comment Share on other sites More sharing options...
kws Posted November 21, 2017 Share Posted November 21, 2017 I need to drill out a stud in my exhaust so I can fix a leaky flange (big fuck you mazda for using a pressed in stud instead of a nut and bolt). My cheap drill bits don’t even scratch it. Where can I get good drill bits (without paying a fortune) and what should I look for? Mine were just a cheap set of HSS (allegedly) ones from repco. Needs to be done on car with a cordless drill so no fancy drill press. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 21, 2017 Share Posted November 21, 2017 Any chance you can hit it with a propane torch to anneal it? Quote Link to comment Share on other sites More sharing options...
kws Posted November 21, 2017 Share Posted November 21, 2017 i have good access to it under the car, so i guess i could. What benefit is annealing it to removal? Quote Link to comment Share on other sites More sharing options...
