The K20A / K24A thread
Roman
Na they don't need head work, the heads and valve train is what essentially makes these things so sweet. Yes you need a tune, you can run a K-pro (hondata) which works with the stock ECU if you wish, think they were around $600. Yea the vtec on the lower spec K motors is cam phasing and intake only extra lift, the vtec is aimed for economy and promoting swirl and shit.
  • Replies 123
Here is the HP register for K20a
http://www.k20a.org/forum/showthread.php?t=34644&page=28
Some highlights.
SET-UP #246
Stock K24a2 (TSX) bottom, stock K24a1 head,
2004 TSX Ex cam,
CTR In cam,
RBC IM,
R-Crew V1,
Thermal 3" exhaust.
Power 246, torque 191
By TheMidasTouch
SET-UP #250
Stock k24a2 (Type S) with a 45 VTC
Stock Cams
Intake 2004 Accord with Type S TB
R Crew Header
3 inch exhaust, 3 inch truck Cat , Magnaflow Muffler
Dyno: Dynapack
Power 250 HP @ 7000rpm, torque 200 Ft-lbs @ 5000rpm
By Choo
SET-UP #234
Stock K24a2 (TSX) bottom end
Stock K24a1 (CRV) head
Skunk2 Stage3 cams
RCrew Header
RBC
Power 262, torque 198
By TheMidasTouch
SET-UP #272
K24 IPS block k20 head
12.5-1 C.R. pistons cunningham rods
Oversized supertech intake and exhaust
IPS KME 8620 cams
Kpro tuned
RBC intake
RC 550s
SSR coated 4-2-1 header
Power 272 @ 7800, torque 220 @ 5500
SET-UP #281
K24a2 (TSX)
Stock head with Supertech valves and valvetrain
CP 12.5:1 C.R. 87.5mm bore pistons
IPS K10 cams
IB rods
TWM 52mm ITB's
SSR header
Power 281, torque 197
SET-UP #339
K24a1 (CRV) / K20a2 (Type S) Head + porting
K20a2 type s pump
Wiseco 87.5mm bore 13.7:1 C.R.
IB rods
Blueprint Racing Camshaft Stage 3 K Series i-VTEC
Blueprint Racing Valve Springs
Blueprint Racing Valves +0.5mm
Blueprint Racing Titanium Retainers
OEM crank
RBC + porting
BDL 70mm Throttle Body
SSR/DTR + Megafon
Power 339, torque 228 with E85
By Honda@racing
Everyone on OS knows the best bang for buck non turbo 4 cylinder is 13b turbo, closely followed by barra turbo, with ls in 3rd.
moral of the story
Why stick with big hp na when a plus t will be better at everything? /offtopic
Max hp na is like retard Olympics just look at my ~100hp mini which i probably dumped over 3 grand of head work into. (Cool head though)
Looks as though there's a W5* gearbox bellhousing adaptor available from Convert Motorsports... Or at least will be soon?
Excuse the ignorance but don't Honda engines run counterclockwise so you will need to do some pretty extensive mods to run a clockwise type gearbox?
I guess the conclusion of this thread so far seems to be...
A K24/20A isnt cost effective in RWD unless you're planning a big dollar big power build which is where the motor excels well past the other 4 cyl NA options.
A standard engine doesnt look to be worth the trouble/$$$ unfortunately, if that's the level of build you can afford.
Lucky for those FWD guys though where one of these plonks in nicely! Always looks awesome having ITBs out the front of the motor rather than the back as well.
322whp K24 been in NZ since ages ago. Invercargill based even, built around 2008.
EK Civic. Did flat 11s from memory. As a Honda kid I was fizzing the first time I saw it in the met
This one here even:
http://nzhondas.com/build-threads/79066-deep-south-ek-k-build.html
Pics are dead but heres a vid, car was sold then threw a rod out the block, has since been turned into a Honda Cup car
So did some more reading of my old bookmarks from when I had a K24 and was going to do some things and gave up. But if you are going for a stock K24 there's a few things that can make it cheaper, if you get the right ECU you can use the stocker to get you going. Also if you do a tweak the F20c factory headers they work and just cut and shut a alloy intake. Gearbox wise for off the shelf shit you are looking at 2K for a box, Flywheel, adapter and clutch. So If you get a decent base engine for the right price that has a ECU and all bolt ons (lots of crashed accords out there) then drop the major coin on the box, shits not so bad $$ wise for a starting point. Stock K24a will pop out 120kw at the wheels or more with a fat mid range and epic economy in a light car. Just has to fit which is probably the tricky part for a lot of cars.
Then when you win lotto drop 5K on it and go dort. Someone on here has to run one on magnesium kinslers haha
Anyway Roman yes they are not some magic bullet for cheap rwd power. But if you are keen to spend a little more then you get one of the best 4 bangers ever made with all of the aftermarket support.
Oh and I still am an advocate of fitting whatever kind motor gives you a boner, if you like blue smoke mitis, kents or whatever do that instead.
But this is what you guys have been pushing them as for the last while?
This thread has been very enlightening though and I'm pleased it's gone as well as it has. I've learnt a lot today.
Very keen to see someone chuck one in something now.
 I think Roman summed it up quite well. If you're down for cheap big power on a budget then they're no better option than anything else out there (N/A) but if you're willing to spend some decent pinga to get a good atmo engine then they're second to none/don't spend a million bucks on something that'll always be in the shadow of a tweaked K
JTune in Auckland has done a lot of work with K24, just bolt ons and tuning this is one of their examples:
Been trying to find some old dyno sheets
On a Stock k24 with intake and exhaust and no tuning can make 140kw at the wheels
Stock Extractor
Orignal Throttle Boddy
No Tuning
Heavy Flywheel
Another Customer CL9 with
Intake
Extractor
Exhaust
Still the small Throttle body and factory intake manifold
And Hondata Tune
It made over 160kw at peak of 6800 rpm
Just the lack of Cam Timing, restriction on the intake and smaller cams we couldnt get more power out of it, but... there is still alot of torque
The ammout of torque it puts out is more then a Stock Nsx with a 3.0 Engine
If you been in a ride in a NSX or a K24 Dc5/Ep3 the pull is similar to a 220wkw Evo at 1.5Bar
These engine makes 200hp Factory
But tuning and right parts combo, is nearly 100hp gain without doing much to the internal.
