Pe-arce's Mk1 Ford Escort Beams Powered Race Car
pe-arce
  • Replies 114
Who's bringing in the life ecu's? Sick with link all day for backup, support and a wide range of tuners.
This is the guy in Ashburton doing the life ecu's.
http://www.avrperformance.co.nz/cms/
http://www.trademe.co.nz/motors/car-parts-accessories/performance/electronics/auction-816031342.htm
Yea it seems link will be the way to go.
Do you know if Richard got my email about it the other day. There was a couple of small changes I wanted to make that differed from the discussion I had with him about it when I dropped it off.. Nothing major just the placement of the harness bar and possibly adding a bar between main hoop once ive finished the tunnel..
Yeah he did. I've got your email at work.
You can see harness bar here. Its between rear stays about 30mm up the stay from the strut tower. So you should be room to be able to get a firewall either side of the strut tower I wasn't 100% clear wgich side of strut you wanted to do the firewall so left enough room for either. That all good?
