  • Replies 154
What's a cool basic round gauge around that is likely to accept Suzuki cable, run from 6V ideally. simple round clean, black ish etc.
Probably cheap nasty plastic fantastic?
CB125 one looks alright . . . is it likely to fit existing Suzuki cable ok?
taken bike completely apart yet?
Haha yup! But I think I should put it back together and actually see how it rides as I realised I have only done burnouts on it since being given it.
Dan's is cool but I think its electrical sender unit run?
lush!
can you run a speedo from a mudbug (TF125/185)? should have all the pilot lamps that you require. designed for 6v. from a suzuki etc etc.
current models even run the same ones they have since the late 70s
mean, my ax100 is surprisingly quick. maybe suzuki a50 speedos would work? i converted the entire front end of mine to cb50 disk break, and got the benifit of using the tiny cb speedo.
are there any bits you need? ive got a shit load left over from things ive swapped out.
lush!
The sweet thing about the TF125 idea is that there will be 100s of them sitting at Suzuki dealers/they'll be throwing them away. Cheapest 'new' DOT stamped indicators you can get are from this source, ~$10/pair
swap mounts over, lower it. but then the bars will stick up heaps?
Agree bars look to high.
Looking for something to lower them.
Maybe something like this? (p clamps)
http://www.ebay.com/itm/Triumph-Handlebar-P-Clamps-7-8-BSA-Chopper-TR6-1970-/321425865039?pt=Motorcycles_Parts_Accessories&hash=item4ad679794f&vxp=mtr
Was going to look at mounting headlight lower also.
