DAD Posted October 26, 2014 Share Posted October 26, 2014 Constructive criticism welcomed and valued Quote Link to comment Share on other sites More sharing options...
Snoozin Posted October 26, 2014 Share Posted October 26, 2014 Congratulations! This little thing is an absolute peach of a car, look forward to seeing it develop. Quote Link to comment Share on other sites More sharing options...
Sparkle Posted October 26, 2014 Share Posted October 26, 2014 Couldn't have gone to a better home! Man this is going to be so super cool with a cam and sidies! Quote Link to comment Share on other sites More sharing options...
Crangie Posted October 26, 2014 Share Posted October 26, 2014 Welcome to the KP owners club.... I just drove mine to Cape Reinga and back not a single issue!!!! Cant wait to watch yours develop! Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 1, 2015 Share Posted February 1, 2015 Vacuum advance has no effect at idle/closed throttle on standard 4K setups. It will start fairly easily with any base timing between 0-18 deg BTDC on standard carbs. Wind your idle mixture screw out a couple more turns as being rich won't hurt it. That should help it start when its cold like that, then wind them in until mixture is correct. Might pay to find someone who is experienced balancing twin carbs, I've heard they can be right bastards. Quote Link to comment Share on other sites More sharing options...
DAD Posted February 1, 2015 Author Share Posted February 1, 2015 Vacuum advance has no effect at idle/closed throttle on standard 4K setups. It will start fairly easily with any base timing between 0-18 deg BTDC on standard carbs. Wind your idle mixture screw out a couple more turns as being rich won't hurt it. That should help it start when its cold like that, then wind them in until mixture is correct. Might pay to find someone who is experienced balancing twin carbs, I've heard they can be right bastards. Good to know about the vacuum advance, thanks! Just went out and made the idles a bit richer as suggested and with a bit of coaxing it started! Sounded rough as hell but at least somewhere to work from. From the look/sound of it i suspect I've got a bit of an air leak around the rearmost manifold bolt (tight spot, silly manifold design, difficult to get a good grip on the bolt) so that's the first place to revisit. Also a few backfires through the carbs and dripped a reasonable amount of fuel out of the 4 barrels when I turned it off, suspect mixture/timing causes for that? (Optimistic) plan was to try to get it into a state where I can drive it to someone to fine-tune. Hoping to try to learn enough to get it in the right ballpark, then I should have a reasonable enough level of knowledge to at least understand where the experts are coming from... We'll see! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted February 1, 2015 Share Posted February 1, 2015 are you sure that vac advance has no play at idle/closed throttle position? because generally that's exactly when vac advance comes into play. i presume youve cranked it enough to fill the carbs with fuel? checked float heights? and is the jetting definatly in the right region to get a start up? otherwise sounds like a pretty big air leak leaning it way out. been there and done all that with the crappy manifold designs when putting bike carbs on my corona, but awesome carbs are well worth the effort and head scratching. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 1, 2015 Share Posted February 1, 2015 Should be able to get that back bolt tight with a 150 mm extension on the socket. Make sure to get that leak fixed before anything else, it will just cause havoc otherwise. Toyota part number 17172-13050 is the best manifold gasket you can use. It is about $27 or something. Quote Link to comment Share on other sites More sharing options...
DAD Posted February 6, 2015 Author Share Posted February 6, 2015 Thanks for the help guys! Had a bit more of a play today. ajg - is that gasket the triple layer 7k manifold? Picked one of those up a few weeks ago. Managed to Dremel down the outside of the manifold to give enough access to tighten it all down properly, no more air leak. Starts and idles reasonably comfortably (though starts creeping a bit high, will need to work on that), but still leaking fuel from all 4 venturis. Not managed to get it up to temperature yet, the idea of fuel dripping on to hot exhaust isn't one that I enjoy! Top of my list for that is float adjustment - gave them a bit of a tweak earlier but didn't cure it. Will try a bit more tomorrow. If no improvement... I can't imagine the stock mechanical pump would put out too high a pressure for the carbs could it?! Would I need a regulator? Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 6, 2015 Share Posted February 6, 2015 Could be the needle that is operated by the float. How long were the carbs sitting? It could pay to get them properly rebuilt by some specialists first. That seems to be what a lot of people do - and then you will know it is done right. Maybe watch/help them do it, would be a good learning opportunity. Only downside is cost. Also yeah that is the triple layer 7k gasket Quote Link to comment Share on other sites More sharing options...
Sparkle Posted July 8, 2017 Share Posted July 8, 2017 But actually, how much longer. Want a ride pls, you can give Mrs Sparkle the drive. I mean... you know. 1 Quote Link to comment Share on other sites More sharing options...
DAD Posted July 24, 2017 Author Share Posted July 24, 2017 Lawlll. P. close, will keep you in the loop Sparklepoos 1 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted July 28, 2017 Share Posted July 28, 2017 If you switch those calipers to a Dynalite (they are a Superlite) they'll fit behind 13" wheels, assume the rotors are a 250mm. I get my Dynalites inside a 13" with about 4mm to spare before it tags the bolts. All my single piece wheels have plenty of clearance. IMG_3160 by Richard Opie, on Flickr Quote Link to comment Share on other sites More sharing options...
DAD Posted July 28, 2017 Author Share Posted July 28, 2017 Thanks for the heads up, but I'm actually running Dynapro calipers - essentially just an updated Dynalite. From the dimensions I've looked at I don't think I'd gain any more clearance from the Dynalites. Rather than being the fault of the brakes, the clearance issue I'm having is due to the silly step in the rear barrel of the equips: Single piece 13s fit fine, annoyingly. Thanks for the thought though! 1 Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted July 28, 2017 Share Posted July 28, 2017 Jelly of you asshole with willwoods, with disc brakes actually! Keed at it mate. 2 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted July 29, 2017 Share Posted July 29, 2017 Well that's a bit stink, I didn't know the Dynalite had been updated.... a bit of a shame to have to mess with the guards! 1 Quote Link to comment Share on other sites More sharing options...
4AGEMAD Posted July 30, 2017 Share Posted July 30, 2017 looking sweet man! Wish i were at your level :'( Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 30, 2017 Share Posted July 30, 2017 I have a pair of 13inch equips that at a guess would be 6inch wide there is a pic of them on my starlet build thread take a look and send me a pm could work somethink out Quote Link to comment Share on other sites More sharing options...
Truenotch Posted August 23, 2017 Share Posted August 23, 2017 I've heard about those Rangey engine mounts before but didn't find them last time I looked. They look sweet. What's the thread size, how tall is the rubber and how rigid are they? Quote Link to comment Share on other sites More sharing options...
DAD Posted August 23, 2017 Author Share Posted August 23, 2017 (edited) @Truenotch I can't remember the thread width, want to say m10? Tons of these on ebay, really cheap too. Reasonably solid, minimal distortion with a 4age hanging off them at 45deg. Edited August 23, 2017 by DAD 2 Quote Link to comment Share on other sites More sharing options...
