not really an update. i put the pipes back on that i originally built it with and mocked up an oil tank that im gonna use. i'll make a mount for it and probs weld it on this week. i'll try amd knock out some seat bungs too and weld them on12042977_10153145918293857_9069551931343
i built up a tyre rack to get my shed more organised
12042652_10153145961183857_3512990719128
  • 4 months later...
  • Replies 84
its been a while since ive done any work on the triumph since ive been getting my vauxhall ready for its wof.
To my surprise it passed 1st time, so its freed me up some time to get started back on my trumpy.
12642732_10153369085458857_4281673138062
So i knocked up some mounts for the solo seat on my lathe and pre drilled some holes in the frame
12742717_10153400375923857_4226065729655
12742455_10153400376048857_8011979705639
I drilled a plate with holes spaced the same as the springs and used that to clamp against the frame so i didnt burn the shit out of my seat
12741989_10153400375968857_4236357293089
12743700_10153400376088857_5302115410848
so now i just need to make the mount for the front bracket to attach to.
Finally got round to making to footpegs, the BSA ones i had originally werent going to cut it and i wanted to use a set of Anderson style pegs that Ive had kicking around.
The right one was pretty simple. I cut a plate out of some 10x25 flat, drilled and counter bored some holes to match those in the frame.
Bent up some 16mm round bar and made a mount on my lathe to accommodate the bolt for the peg.
12963400_10153546582178857_8876638062286
Same sort of deal for the left hand except 2 bends to clear the primary cover and a shaft for the brake pedal to pivot on
13015303_10153554147783857_1650553762500
12993489_10153554147843857_6242122526968
I was fucking about in the shed and was looking at the bars and decided to swap them out for a set i had in box and had been humming and harring over for a while. I payed $5 i think at the mcleans island swapmeet.
Pretty happy with them and theyre staying on.
Next up is to mount the mudguard and mount an oil tank.
13151471_10153590765458857_5015949537345
13087700_10153590765528857_5396365114060
13151559_10153590765563857_3475793879906
  • Like 8
shit you have a lot of fuel tanks
If they're cheap enough I'll buy em, even if I don't need them.
I've got a thing for zundapp tanks too
I decided against using my round aluminium oil tank and chose to use what i think is a Pre-unit oil tank.Using a flat bit of 5x25mm flat steel with holes drilled either end I bolted the flat bar to the bottom hole on the engine mount on the seat post and the oil tank to the other, just to hold it into position whilst i figure out mounts for it.
13103369_10153596915813857_8416232357078
  • 6 months later...
awesome! will keep an eye out for you at the burt.
cheers man, unfortunately we wont be going down in the bedford anymore, we're gonna go down in my dads car and tenting in a camp ground.
So yesterday i tacked the rear mudguard mount on that id bent up during the week. To bend the round bar i just used my cheap pipe bender. I was surprised at how good it came out. When i was at work i bent each side to get the right distance to the bungs that I'd drilled and tapped to the dropouts. when i got home to mount it it looked like shit, it looked too bulky.
15036549_10154085308083857_1141966664450
When i bent the legs at work i bent them too far down. so to straighten them i put one leg in the vice and it seemed to do a decent, tried the other one and....
15107260_10154087897233857_6883753113589
I didnt really expect much else from it to be honest.
So I went out to my shed at Tuahiwi and used my shop press which did a better job. I shouldve waited to use that but i got a little impatient.
Here it is just tacked together. I'll fully weld it up at work or when i have some spare time at home.
15055808_10154089949513857_374135390672515094359_10154089949218857_5199018557520
15056232_10154089949163857_6728244406961
I also made a little brake rod thing to attach it to the brake pedal. Before I'd just threaded the end and bent it and kept tit on with a couple of nuts and washers. It was just temporary until i could figure another way of doing it, So i made this.
15094294_10154080478398857_4800884343711
  • 1 year later...
This things been put on hold for a while. Pretty much too many projects and the missus not too happy about me working on them. Plus they're all out at my parents place.
I've been trying to spend my time getting my Vauxhall and cf Bedford roadworthy. So it's about time I got started on it again. Put on a headlight I've had stashed for a while. Really suits the style of the bike.
  • 2 years later...
Shit 2 years since I last posted about this bike! This year is gonna be the year I really put some more effort in to this thing.
I got these forks to replace the current ones. I'm gonna shave and polish the lower legs and give them a general once over.
Other plans for the bike are to remake the hardtail, so I'll get some tube ordered at work and get it bent up and fizzed together and transfer all the parts from the current engine into some good condition cases that I've got stashed away.
Today I threw those forks on to see how they'd look,  I'm thinking a 2inch drop to get the frame rails parallel with the ground, but overall I'm pretty happy with them.
I also made a start on the exhausts with some 180 bends i had lying around. I'll get some more bends to do the other cylinder when I get the chance.
  • Like 9
