98cc's Ordinary Bicycle Build
98cc
I am flying down to chch tonight, and then going to Oamaru tomorrow morning and spending the rest of the week making the rims, backbones, spokes and tyres. I will try to take as many pics as possible
  • Replies 97
Yup they are a solid piece of rubber with a wire through the center. You first cut the rubber slightly larger than the circumference of the wheel, you then lay the rubber around the rim and using a special tool tension the wire until the rubber is tight on the rim and then braze the ends of the wire together.
Thanks born looser and rot808. If you ever want to do one bl, get in touch with Grahame Simpson in Oamaru. He is extremely helpful.
Yeah it should be a good thing for leadfoot and roycroft events Amy!
Rustisize, Grahame gets the engineering company in oamaru to do it. They have a big press and the just swage the taper into it.
I have got the rear forks all finished and welded on now. The hubs i got from the guy in Oamaru, they are just steel front hubs off a normal bike. The rims are all drilled and ready for painting so hopefully that will happen this weekend.
  • Like 9
Thanks born loser, the bits for my bike have cost about $700. The long spokes are $4 each and the tyre rubber is $40 a meter so these were the main costs. I wont need to buy anything else apart for some paint to do the forks and frame from this point though
Thanks BVB, I need to get them finished for the ride I'm doing in October. It's quite good knowing you need to get something done by a certain date or else you won't be able to do the event that you have already paid for haha.
Thanks Tortron, no i dont think i will do any lug detail, the ride is only a month away now and i still need to get both of the bikes painted and do all the final details. A good replica penny will generally sell for between $2-3000 even up to $4000 and originals are well into the 7-15k range. I got my bike welded up on the weekend so i will do a big update sometime this week.
