crownin round Posted August 25, 2014 Share Posted August 25, 2014 I'm swapping front springs over in the crown or trying to. Was wondering how to go about removing the springs have tried removing the lower ball joint but having no luck so far any help would be appreciated. Spencer, seedy, josh, etc one of the many ex owners tips and tricks would be sweet. cheers Quote Link to comment Share on other sites More sharing options...
AllTorque Posted August 25, 2014 Share Posted August 25, 2014 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted August 25, 2014 Share Posted August 25, 2014 if you don't have a fork for releasing the ball joint just smack the spindle with a hammer where the bj is. make sure you leave the nut on a couple of threads to catch it when it lets go. Quote Link to comment Share on other sites More sharing options...
dave Posted August 25, 2014 Share Posted August 25, 2014 balljoint splitter Quote Link to comment Share on other sites More sharing options...
Bling Posted August 25, 2014 Share Posted August 25, 2014 Don't need a splitter if you hit it like a man. -edit- I can probably help whack it at some stage. 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted August 25, 2014 Share Posted August 25, 2014 Or just go and buy a splitter.. one of my fav tools, turns a cunt of a job into a piece of piss Quote Link to comment Share on other sites More sharing options...
Bling Posted August 25, 2014 Share Posted August 25, 2014 Wanna race? Splitting the boot eliminates you from the race btw. I must be missing something though... the last one I did I just had a sledge behind the bj spindle thing for support, a couple of good cracks with a hammer later and the bj popped out the bottom, boot untouched. Never hit the bj. My offer was legit too, I have multiple hammers of varying awesomeness. Quote Link to comment Share on other sites More sharing options...
crownin round Posted August 25, 2014 Author Share Posted August 25, 2014 i would take up your option but my hammering so far has had no luck but car is up north hahaha and no racing still a sequence of how to go through taking the suspension apart would be nice Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 25, 2014 Share Posted August 25, 2014 its to late tonight for me to write something up but its not a major hard will try get some time tomorrow and post how I go about it. Quote Link to comment Share on other sites More sharing options...
downtrail Posted August 25, 2014 Share Posted August 25, 2014 i would take up your option but my hammering so far has had no luck but car is up north hahaha and no racing still a sequence of how to go through taking the suspension apart would be nice You need to hit harder lol ive never used one of those splitter things as they wreck the boot. Unless your replacing the ball joint then sweet as. Just wak the shit out of the piece the ball joint taper goes through itll break eventually. Quote Link to comment Share on other sites More sharing options...
crownin round Posted August 25, 2014 Author Share Posted August 25, 2014 cheers guys will try some more whacking in the morning scared of breaking things Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 25, 2014 Share Posted August 25, 2014 Quick run down. Remove both top sway bolts off the lunks so the sway bar can be swung up out of the way. Loosen the two 17mm bolts that hold on the bump stop and caster rods. Loosen the large caster rob bush bolts at the front of the car. Remove shock. Undo the lower ball joint but leave it on a few threads. Break taper on the lower ball jpint by hitting it hard until it comes loose and tge nut is now holding the pressure. Now remove tge caster rod nuts you loosened earlier and then undo the two underneath that hold on tge bump stop. You can now remive the caster rod. Put jack under lower arm so you can unwind the rest of the lower ball joint. Then lower the arm slowly to let the spring tension free up. Remove spring. May need to use a large leaver to pop it out. Install is reverse up be aware its alot harder getting the non cut springs back in. 2 Quote Link to comment Share on other sites More sharing options...
crownin round Posted August 25, 2014 Author Share Posted August 25, 2014 Thanks heaps man got the first spring done had to get the brother to sit on the car to get the spring in have made a set of spring compressors for the second one and further use in the triumph Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 26, 2014 Share Posted August 26, 2014 Oh rad. Just make sure the spring is located in the top spring mount properly, as often given the arch you meed to push the spring through to get it to sit in the bottom perch is often enough to push it out the top. Quote Link to comment Share on other sites More sharing options...
