maxted Posted July 19, 2015 Author Share Posted July 19, 2015 small progress this weekend finished handbrake set-up today and adjusted up under body shot while i was down there still need to drop it down to see how it sits with reset leaves found a new coil i forgot i had score! also got a new slave cylinder but it does not come with a push rod and i don't have any old ones to pinch the push rod from, does anyone have one laying around they could measure so i can make one? 1 Quote Link to comment Share on other sites More sharing options...
maxted Posted July 20, 2015 Author Share Posted July 20, 2015 picked up the radiator from being recored today, looks good. not cheap but wanted to keep original copper jobby. sat it in, need to source some new hoses, and hook up the heater hoses also next job is to get the exhaust done 4 Quote Link to comment Share on other sites More sharing options...
maxted Posted July 23, 2015 Author Share Posted July 23, 2015 towed it down to work to do the exhaust i had over adjusted the brakes, so adjusted them again today and backed them off a bit, sits at not a bad height id almost say it needs to go down slightly more in the rear just a touch? chucked the new dizzy bits together and checked the lead lengths, looks all good, need to suss the wiring for it next exhaust has been made and sitting in place, just needs the mounts welded on then pull it out to paint then back in and weld muffler in, stoked with the job they did need to get the carb back on, suss more wiring and grease every thing while its up on the hoist. also have the little brothers escort down the shed, t has a 12a and s1 box that needs the gearbox out, it crunches into 2nd and 3rd. 7 Quote Link to comment Share on other sites More sharing options...
maxted Posted July 30, 2015 Author Share Posted July 30, 2015 exhaust is finished, looks good all painted and done, i removed the lsd and put the open head back in, wired up the taillights and have painted up headlight buckets getting ready to put the front back together, still need to put the new clutch hose in and test it for free play/set it up. also need to try and find/trace the oil pressure and water temp wires from the dash and remove all the extra wiring for the rotary, lots of little things to go, just going to get it going and worry about interior after driving it for a month or two. 6 Quote Link to comment Share on other sites More sharing options...
maxted Posted August 23, 2015 Author Share Posted August 23, 2015 no real progress on this other than archetype is making some side stripes for me. has anyone had any experience with these repro carburettors on ebay ect? I'm tossing up wether to just get one of them or mess around re-kitting one of the originals i have would be nice for one to turn up and just bang it on if they are not too bad quality. going to clean up a air cleaner for it then thats the engine bay mostly done except for wiring. Quote Link to comment Share on other sites More sharing options...
maxted Posted September 24, 2015 Author Share Posted September 24, 2015 its been a couple months since i have actually done anything to this, but after spending a couple weeks on holiday Im getting back into it, have got a carb kit and have pulled to bits my spare carb to re-kit it and will keep the one that was running on the engine aside incase i cock it up! Im hoping to get it running in the next couple of weeks just need to sort some wiring for coil/dizzy and suss out a fuel line from the hard pipe to carb. also i have ordered some semi-sealed headlights to replace the crappy sealed beams that have blown, will be good to run some decent h4 bulbs, hopefully they will turn up from oz next week. going to order some door rubbers off ebay as I'm sick of the doors rattling around in the latches! heres some photos of the carb partly cleaned up, tricky little buggers with fiddly little pieces, my first time pulling one to bits Quote Link to comment Share on other sites More sharing options...
maxted Posted September 25, 2015 Author Share Posted September 25, 2015 headlights turned up last night, fitted one side to see how they look, had to modify the inner buckets to get them to sit in properly but i think they look all good looking forward to getting these put on next week! 3 Quote Link to comment Share on other sites More sharing options...
Popular Post maxted Posted September 29, 2015 Author Popular Post Share Posted September 29, 2015 cheers to archetype 31 Quote Link to comment Share on other sites More sharing options...
maxted Posted October 4, 2015 Author Share Posted October 4, 2015 been tackling the wiring in this to remove all the un-needed wires from the rotary conversion and to track down the original wires for the water temp and oil pressure, workshop manual came in handy to help locate them, pretty nice job the previous owner has done on the loom and new fuse box ect, will finish running them where they need to go and wrap it back up, for some reason the fuel pump won't go when its wired into the loom but i hard wired it to the battery to run the engine briefly was good to hear it run after all this time getting close now, next job after the wiring is make a new clutch hard line as the lines to short to reach the new hose with the clutch back in the piston engine position, then hopefully test drive this week sometime. 1 Quote Link to comment Share on other sites More sharing options...
maxted Posted October 24, 2015 Author Share Posted October 24, 2015 so i have removed most of the un-needed wiring in this, then re-wired to suit the piston motor, also replaced the oil pressure sender and water temp sender and found the wiring to suit. then hooked up all the cooling system with new hose and clamps and filled it up, finished hooking up the fuel line. so then i fired it up after getting the timing sorted, it runs quite nicely... but it smokes like a bitch…. pretty gutted and something is not right in the clutch department, have a strange noise until i press the clutch, don't know whats going on in there everything is new. but i did find it must have a different clutch fork as it doesn't line up with the slave and puts the pin on a weird angle. but its looking like motor and box back out. tossing up wether to give the VC 1800cc motor a freshen up and use that instead and try find out what the heck that noise is in the clutch area. the gearbox has been leaking from the joins in the housings too so i might use another box or pull that one to bits and re seal it. also the gearbox is just fouling the tunnel when it shakes so might be easier to re-shape the hole and hammer a bit more clearance with the box out anyway. bummer more work to do yet 2 Quote Link to comment Share on other sites More sharing options...
maxted Posted November 13, 2015 Author Share Posted November 13, 2015 got the 1800 block back from the machine shop today its had a dip and hone, also got them to have a measure up to make sure its all-good to go, its still standard bore size and pistons are still good. few gaskets and some new rings, to give it a bit of a birthday. hopefully have the rest of the bits next week and start piecing it back together, also pulled the spare gearbox to bits to check it over, glad i did as one of the bearings had given way on the secondary shaft. 4 Quote Link to comment Share on other sites More sharing options...
maxted Posted January 1, 2016 Author Share Posted January 1, 2016 picture-less update, pretty much haven't achieved a lot on this lately, have put the pistons and crank back in with new rings, bearings and thrust washers. just getting the head back together to go back on, its been away to get planed as it had a small bow in it, tore down the spare gearbox to find a bad bearing so have replaced that and its ready to go back together also thinking of putting the internals in the housings of the gearbox in the ute already cleaned up. hopefully have it on the road shortly! 2 Quote Link to comment Share on other sites More sharing options...
maxted Posted April 10, 2016 Author Share Posted April 10, 2016 so long time no update, over xmas/ new year break got impatient with piecing back the VC engine together and brought a MA and 5 speed from a 626 and dumped it in, but since then we brought a place in Jan and this got pushed into the back of the garage and covered up. probably should try get it on the road sometime soon. needs all the ancillary bits and pieces swapped over and wired back up, some new oil in the motor and box and see how it goes, fingers crossed its a decent gearbox too. 3 Quote Link to comment Share on other sites More sharing options...
maxted Posted April 22, 2016 Author Share Posted April 22, 2016 pretty happy, today i got it running with the MA engine and its not smokey, no strange noises from the engine and no strange noise from gearbox/clutch….. success. took it for a small drive around the block but not very far as it needs a fan belt to drive the water pump as the old one won't fit as MA has a different alt set-up and a different water pump pulley. so off to get a belt tomorrow and bolt the bonnet back on then proper test drive 9 Quote Link to comment Share on other sites More sharing options...
maxted Posted April 26, 2016 Author Share Posted April 26, 2016 wof time tomorrow see how big the list is I get engine bay is staring to look tidier after swapping over more of the cleaned and painted parts over from the lemon that once resided in there 7 Quote Link to comment Share on other sites More sharing options...
Popular Post maxted Posted May 1, 2016 Author Popular Post Share Posted May 1, 2016 well it is all legal after a few minor things like park lights and a indicator and getting horn to work but……. since then it has developed a massive oil leak from the back of the head and is now smoking! So as I'm not to fussed on pissing around much more with these old carby engines I have found a mx5 motor and bellhousing and am going to do the swap for fuel injection life. may as well as it was always the plan for reliability and economy just had hoped to at least use it for awhile as it is. if i get motivated i may try chuck a gasket at it and see if it comes right and use it for awhile until i have all the conversion worked out. here is a very technical drawing of the plan of attack 24 Quote Link to comment Share on other sites More sharing options...
maxted Posted May 14, 2016 Author Share Posted May 14, 2016 the fella I am acquiring the mx5 engine from has sent me this photo of the motor pulled from the car just the wiring loom to come out and split the bellhousing from gearbox then its ready to go. got bit excited and brought some goodies to give the b6 a spruce up when it arrives, also thinking of rewiring the non engine side of the loom while I'm sorting out the mx5 loom to suit by putting in a new fuse box ect, give the lighting side of things some relays. 6 Quote Link to comment Share on other sites More sharing options...
maxted Posted May 22, 2016 Author Share Posted May 22, 2016 engine turned up today, got it onto a stand ready for a good degrease and some paint ect the fella i got it from was such a good dude and cut all the sections from the loom i needed and given me the front half of the mx5 box to put onto my 626 box. plan is to clean it up and give it a paint, do the water pump and cam belt, then try get it in and make some mounts. while I have been waiting for the motor to turn up have done a few little jobs, have cleaned up the spare wheel and given it a paint ready to put a tyre on and winch it up in place, have also dug out the front discs and worked out they are UN courier vented discs, have moded some top arms to take the newer style top ball joint by moving one hole and slightly elongating two other holes, need to see if i can find the spare lower arms to see what is needed to fit lower balljoint or if the old one is the same taper ect, also about to clean up the tow bar ready to paint up and bolt on 6 Quote Link to comment Share on other sites More sharing options...
maxted Posted May 23, 2016 Author Share Posted May 23, 2016 found a sweet pin out diagram for the mx5 ecu so thought it might make life easier if i label all the wires. going to make a mounting bracket to fit the ecu up in the passenger kick panel and maybe put a fuse box and some relays next to it. this is Teddy degreased the motor today, ready to strip it down for cam belt ect 7 Quote Link to comment Share on other sites More sharing options...
maxted Posted May 24, 2016 Author Share Posted May 24, 2016 so it turns out as Sam the slacker kindly pointed out today, the mx5 sump bulge is at the wrong end for slotting in the ute and would foul the steering/xmember…... luckily i managed to find a bfmr b6t engine that I was going to pinch the rocker cover off but ended up grabbing the whole engine so i can nab the sump and pick up also, i pulled it all off tonight looks as tho it would work. will find out tomorrow 3 Quote Link to comment Share on other sites More sharing options...
