J-W-G Posted June 6, 2014 Share Posted June 6, 2014 Having not updated my thread in a while due to rethinking what i want from the escort ive decided to establish a new thread to better summarise my escort from then till now. Without further adue... I picked up my escort as my first car when i was 15. Being a Ghia it was essentially a 4Door sport with added chrome and lush interior. It needed a small amount of work for a wof like front indicators, rust repairs etc, but the running gear was in good nick. It had a 1600 X-flow backed by a close ratio 4speed gearbox and followed by a 3.54 diff. All in all a lush package for a young fella to ticker with. J-W-G 4 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted June 6, 2014 Author Share Posted June 6, 2014 After buying the escort and driving it round till i finished school the world of BDA escorts and Zakspeed cars really began to get my attention. I had big ideas of 6 linked and fully adjustable suspension, large diff and trans tunnels and stripped interior. This coupled with me joining the army has lead to the escort sitting lifeless for the past year and a half while ive gathered parts. 1) Diff conversion I chose a Ford Courier/B1600 diff from a 78 model gave it a test fit and all seems well. The spring saddles are near identical and it ends up being 20mm larger Escort being 1350mm and Courier/B1600 being 1370mm. I then proceeded to take the diff apart to inspect it and was pleasantly surprised to find it has huge grease packed semi floating hubs I then had to get the big 6 stud face machined down to accommodate my sierra cosworth rear disks with my Laser TX3 rear calipers. Next up was the 4.1 LSD diff head from a later model courier with the 2600cc G6 engine. It required some mods to fit... well maybe just a kiss to the housing with the angle grinder. Time then came to put it back together Grease her up. Wack her back together then done Its nice and tight and diff head turns freely and as it should. J-W-G 3 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted June 6, 2014 Author Share Posted June 6, 2014 2) Brakes After much surfing the net and alot of luck i managed to source some austin princess calipers with some new stainless pistons which i had to fit along with a spacer kit to take the KE Laser TX3 Turbo disks i plan on running as its a bolt on swap. Oh and mitch also got these welded to my capri struts I then got these bits Just waiting out on adjustable dampers and roller bearing top mounts J-W-G 2 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted June 6, 2014 Author Share Posted June 6, 2014 3) New engine I settled on the engine conversion i wanted to do start of last year after being in awe of Low n Slow's FE3T escort since seeing it on the tarmac at the 2011 nats. Accept i really wanted the dooort sound of ITB's or carbs... Next was to find a gearbox to suit. Mx5 to the rescue, i found a really cheap rebuilt box with not even a drop of oil. I then had to get a Courier/B2000 box to change the bellhousing to suit the FE3. With decent carbs these days demanding top dollar i went with a set of silvertop itb's to hang off the side of the head. Next was to assemble a mix n match of mazda bits to make a hybrid BP/B6/FE3 Crank angle sensor. It runs the BP/B6 cas body with the FE3 guts and top cap. In my giddy excitism i promptly put every thing together to test bolt holes etc After doing some research on the engine i found Kia had used it in their first gen sportage. I liked the look of the cam cover so had a go at making my own BDA inspired cam cover. All im waiting on now is for a Courier/B2000 FE Flywheel, engine mounts, sump + pick up, spigot bearing and new clutch J-W-G 2 Quote Link to comment Share on other sites More sharing options...
Popular Post J-W-G Posted June 6, 2014 Author Popular Post Share Posted June 6, 2014 4) Future Plans My plans for her for this year/coming years is to give her a fresh new coat of the factory creme colour, polished chrome and factory interior followed promptly by a lush set of wheels. Next is to fit the engine and gearbox followed with the fuel and management system Followed by refreshing the front end with new adjustable TCA's, anti dive kit and urethane bushes all round. Oh and looooow LUSH J-W-G 13 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted December 26, 2014 Author Share Posted December 26, 2014 5) Suspension I managed to pick up a full set of brand new Gaz adjustable dampers for the front and rear and managed to treat myself to a new set of coilovers which suited way better to my needs. This was the front set up before welding. Specs are 220lb springs, followed with keeper springs and adapted Cusco Evo strut camber plates. Struts after welding. Vern had to machine out the spring tops to accept the Gaz inserts, then lathe up some spacers to take the camber plates. Further the camber plates had the be redrilled to the Escort "small hole" PCD of 95mm. After a small bit of massaging the bolt holes i got the strut tops in followed by... The TX3 Turbo rotors were a bolt on fit and take up the whole pad of the Princess calipers which is bloody great, also the rotors are a shit ton cheaper then Capri vented ones at $50 for two. The rear ended up looking like this... The spring plates needed a quick weld up and redrill to accept the larger Courier/B1600 U-Bolts. Plans from now. Right now the car is nearly rolling. I just need a set of wheel studs to get it on some wheels so i can move it outside to do some work on it while having a beer and getting a tan. Just waiting on a shipment from the UK with some flash new parts for the front end. For the rear just waiting for the new year to get the leafs reset for a 2inch drop, sand blast and powdercoat (Suggestions?). Stay tuned for what ive been doing to the engine, its getting there but its got some cool stuff to do with itb manifolds and a lush stainless octopus hanging off the side... J-W-G 9 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted December 29, 2014 Author Share Posted December 29, 2014 6) Engine Doort... Everything bolts up nicely and without hassle! The exhaust was originally off an AE86 race car, its a stainless 4-2-1 design with 45mm primaries, 50mm secondaries with a 2.5inch outlet. Only thing i had to get done was the 4AGE flange cut off and a new stainless FE3 flange welded on. The itb manifold is a cut and shut job done by Vern, he had to build up the weld to meet the itb flange i got cut as the original FE3 manifold was never totally round. Ihave some VR4 injectors from KPR that sould do the trick and just need to be mounted. I then decided id do some porting on the intake to smooth out the welds and casting marks. Still a way to go as i now have to sand it by hand as my dremel piece isn't long enough. Plans for 2015 for the engine is to do a full rebuild on it and sort out ignition and management. Im thinking a Link G4+ Atom or a megasquirt (give me pros and cons of both in discussion) and a ford edis module for the spark. //oldschool.co.nz/index.php?/topic/30700-pures-80-escort-ghia-of-extreme-imperfection/page-6 CHUR BRO'S J-W-G 6 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted April 6, 2015 Author Share Posted April 6, 2015 Goodness 5 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted July 17, 2015 Author Share Posted July 17, 2015 Look whats in the bay Pretty stoked to finally get this thing fitted, its snug as hell but looks good. X-Flow out Gearbox lines up with the hole, will need to cut the original mounts out of the tunnel to get it to fit but looks like it will be tight. Might have to change the tail housing to one from the courier box as its flatter. Ready to go... Cheers to Chris aka Low N Slow for the mounts, wiring and Link, and the adjustable cam gears. Will further fit the gearbox and clean up the engine bay more when im back home, things are looking up! 8 Quote Link to comment Share on other sites More sharing options...
Popular Post J-W-G Posted December 3, 2015 Author Popular Post Share Posted December 3, 2015 Oh hi there... 11 Quote Link to comment Share on other sites More sharing options...
Popular Post J-W-G Posted January 28, 2016 Author Popular Post Share Posted January 28, 2016 Well, well nothing to exciting has really happened to the Escort, I mean i havent done anything exciting to the Escort. Its in at Hewie's Garage in Dannevirke getting all of the panel work pristine so stay frosty. To pass the time over the christmas break was really me sorting the Cortina out to haul back down to Christchurch and making a custom dash cluster for the Escort which ive made out of MX5 bits, anyway to pictures... So bought a normal 'L' cluster and got the hole saw out for two 45mm holes Broke off the original plastic mounts and re glued them to suit the MX5 gauge mount points. Was a near perfect fit with me having to dremel some of the plastic on the back. And the finished product, needed a lick of black satin to clean up the new cut holes. Overall the gauges are a bloody good fit and suit the escort pretty well. Hopefully more updates pretty soon once the panel beating is all done but to do list FE3 + Gbox mounted and running Dash pad reupholster Nardi Torino Rear leaf reset Brakes/hydraulic system sorted Slam and wheels J-W-G 10 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted November 5, 2019 Author Share Posted November 5, 2019 Damn over 3 years and no updates... Got the escort down to Chch, bought a mk1 escort, sold a mk1 escort, bought a house, was away for 8 months overseas with work, sold the courier, bought a ranger and life has just gotten in the way while projects have taken a back seat. But back to it... Pics of the MK1 I had to fill the void Back the MK2, so i sold the Courier diff as it was just too big and im not planning on making heaps of power. Went and got another standard escort diff which ill put a quaife ATB LSD into and if i end up breaking axles ill buy some off the shelf semi floating axles. Still planning on rear disks of the P11 primera type as palmside sell a kit. Had a wee tinker with the front brake set up as im not too happy with the princess 4 pot calipers, they are so damn heavy. Bolt on yes, bigger pad than M16 yes, heavier yes. Ive had some FD rx7 4 pots sitting in the corner for ages so decided to cut up some angle steel ive had lying around and see if i can adapt them to fit. Was super easy with some crude measuring and managed to at least get them mounted. They fit pretty well and the pads contact the 260mm disk bloody well. Will change from KE laser disks to BMW E30 vented items as they are 22mm thick as per rx7. Best thing is they fit inside 13inch wheels! Gearbox is finally attached to the dummy block and comes out of the original gearhole which is a plus 8 Quote Link to comment Share on other sites More sharing options...
