Popular Post kicker Posted May 16, 2014 Popular Post Share Posted May 16, 2014 Yay a new bike! I picked this up yesterday, a Yamaha RD400 I had one years ago but it grenaded itself and spent the rest of it's life as an ornament in my bedroom while I was at uni This one is 95% complete, main things missing are cables and a rear master cylinder. Came with some yummy expansion chambers and clip ons Fun times 14 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted May 16, 2014 Share Posted May 16, 2014 Was gutted when I read about GS . Now I'm very excited! So rad dude! Plans? Modify ? Quote Link to comment Share on other sites More sharing options...
Goat Posted May 16, 2014 Share Posted May 16, 2014 Fuck you rule Quote Link to comment Share on other sites More sharing options...
kicker Posted May 16, 2014 Author Share Posted May 16, 2014 Gonna get it legal then change a few things, I might ditch the wagon wheels for some wire ones, the loaf of bread seat is getting the heave ho and the rear part of the frame will get trimmed down, maybe a Kenny Roberts inspired paint job Just found it's missing the oil pump so premix it is 5 Quote Link to comment Share on other sites More sharing options...
kicker Posted May 16, 2014 Author Share Posted May 16, 2014 Pics for inspiration This one is sweet, RD400 frame with banshee engine and TZ tank Drilled fins 5 Quote Link to comment Share on other sites More sharing options...
tortron Posted May 16, 2014 Share Posted May 16, 2014 This is pretty much what im looking for in my next bike. Will be following for ideas Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 16, 2014 Share Posted May 16, 2014 You rogue, this is awesome! Quote Link to comment Share on other sites More sharing options...
Rookie Posted May 16, 2014 Share Posted May 16, 2014 Fuck this is awesome! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 18, 2014 Share Posted May 18, 2014 ive got no idea about big bikes, but the tiny 2 strokes we play with have oil injected main bearings sometimes, so removing the oil pump can lead to blown crank bearings, may pay to just double check the system your bike uses before converting to premix. super sweet bike though! Quote Link to comment Share on other sites More sharing options...
kicker Posted May 18, 2014 Author Share Posted May 18, 2014 It's all sweet, these things just pump oil into the carb. Just need to block some ports and go up 1 main jet size (need to rejet for the pipes anyway) Also I'm gonna make a pressure tester to check my crank seals, it should hold 6lb for 6 mins if they are in good nick Quote Link to comment Share on other sites More sharing options...
KIRK Posted May 18, 2014 Share Posted May 18, 2014 mean bike bro just spray crc around the seals when its running/look at how much oil leaks out etc and u will see if they ok /if it starts easy they are sweet its easier to tell on a small single tho u can almost feel the crankcase compressions by hand/u can feel when its got nothing lol Quote Link to comment Share on other sites More sharing options...
kicker Posted June 16, 2014 Author Share Posted June 16, 2014 Have been tinkering with this as parts arrive. There seems to be pluses and minus' with everything on this bike. The carbs were missing their return springs but it turns out they are RZ carbs as are the inlet rubbers with balance pipe. Rear suspension is in good condition with fresh grease, the front forks don't match and one of the lowers wasn't bolted on. Engine is missing base, head and exhaust gaskets but the cylinders, pistons and rings look good. I had to pull the engine to fit the DTI in order to time it correctly but it only took 5mins from all hooked up in the frame to sitting on the bench Since the top end is off I might just split the cases and replace all the seals and any bearings that need it. I found that I still have the clutch holding tool I made for the last one I had nearly 15 years ago haha Can't wait to fire it up 6 Quote Link to comment Share on other sites More sharing options...
Goat Posted June 16, 2014 Share Posted June 16, 2014 Mate. This is mean. Can't wait to hear this running. Tis weird how you seem to have a knack for buying bikes with the weirdest shit missing. Quote Link to comment Share on other sites More sharing options...
Steelies Posted June 17, 2014 Share Posted June 17, 2014 dude. Quote Link to comment Share on other sites More sharing options...
Goat Posted June 18, 2014 Share Posted June 18, 2014 1 Quote Link to comment Share on other sites More sharing options...
kicker Posted June 18, 2014 Author Share Posted June 18, 2014 Whoop More fun, it appears the cylinders are from a different RD, mega amount of clearance and ring gap is about 2mm! Not sure why the mismatch, but lack of gaskets and head bolts not done up points to them just being plonked on for sale, by a few previous owners down the line I think Just going to get cylinders sorted for some new oversize pistons jeah, 2mm over stock gives an extra 25cc haha Eye candy Would love some radial finned heads 4 Quote Link to comment Share on other sites More sharing options...
rot808 Posted June 18, 2014 Share Posted June 18, 2014 Fuck this is sweet Quote Link to comment Share on other sites More sharing options...
Big Value Buddy Posted June 18, 2014 Share Posted June 18, 2014 Lucky you know what you're doing! I'd have cried long ago with the things you're discovering! Eye candy number 1 is delicious. I like your thinking sir. Quote Link to comment Share on other sites More sharing options...
kicker Posted July 14, 2014 Author Share Posted July 14, 2014 Pistons jeah Cylinders were whack, one measured up as 65mm and the other was 64.5mm widening to 64.75, pistons were stock 64mm size so definitely jumbled together from other bikes. New pistons are 65.5 so an extra 18.9cc's wowee, will drop cylinders off this week to be bored. Ordered a full set of gaskets and seals, just waiting for the last ones to arrive now before opening up the crankcase 7 Quote Link to comment Share on other sites More sharing options...
Goat Posted July 14, 2014 Share Posted July 14, 2014 I like where this is going. Quote Link to comment Share on other sites More sharing options...
