MKD Posted July 29, 2014 Author Share Posted July 29, 2014 bar candy next its switchblocks & wiring them in. Getting some posh style ones 3D printed at the moment, hope they work out 1 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted July 29, 2014 Share Posted July 29, 2014 Nice dude !!! Quote Link to comment Share on other sites More sharing options...
MKD Posted July 31, 2014 Author Share Posted July 31, 2014 3D printing came out OK - its a little rough but easy to clean up being plastic. One of the switch housings doesn't quite fit the larger switch for the headlights, but it shouldn't be too hard to persuade it. Stoked overall though - cost about $15 for these two out of black ABS 2 Quote Link to comment Share on other sites More sharing options...
MKD Posted August 6, 2014 Author Share Posted August 6, 2014 question on kill switch wiring.. I've got a momentary on/off switch and looking to wire it as a kill switch. My theory is it gets wired between the coil primary (my thinking of coil primary is the small wire on the stator side?) and a good ground...so in effect when the switch is depressed for a while it grounds the stator charge and kills the plug spark/supply to the HV coil? correct? or tell me how. Chur Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted August 7, 2014 Share Posted August 7, 2014 That sounds about right . That's how my C50 is set up Quote Link to comment Share on other sites More sharing options...
MKD Posted August 7, 2014 Author Share Posted August 7, 2014 Sweet ill give it a go Quote Link to comment Share on other sites More sharing options...
MKD Posted August 11, 2014 Author Share Posted August 11, 2014 Update pic dump. 3d printed switchblocks fit sweet. Was a bit suss drilling out 16mm holes in a 22mm alloy bar but think it should be ok as long as i dont do jumps...the posh switches are in inch and 7/8 so there'd be more meat left on the inch bars. Still need to tap a 3mm hole for the screws and wire everything in. Got my rego notice in the mail just now lol. Been on the road about 15mins total out of that 6month rego...possible 40mins if you count pushing it home! Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted August 11, 2014 Share Posted August 11, 2014 Looks really sharp mate !! Quote Link to comment Share on other sites More sharing options...
MKD Posted August 28, 2014 Author Share Posted August 28, 2014 Progress...got the wiring sussed and headlight fitted. Stoked the OEM headlight fits sweet into the vintage housing. May have to adjust angle a bit, but its pretty good so far. next is fitting tyres - bought some Shinko 241's ala postie bikes, and painting wheels what are people using as seat bases at the moment? skateboard wont fit properly, have no sheetmetal facilities (or skill haha) really, I could possibly fibreglass something...ideas? Quote Link to comment Share on other sites More sharing options...
MKD Posted November 11, 2014 Author Share Posted November 11, 2014 Bout time for a pic dump Seatbelt webbing to be sewn together then figure out some way to mount the seat... Quote Link to comment Share on other sites More sharing options...
davejayed Posted November 24, 2014 Share Posted November 24, 2014 this is a cool project, I've just restored an fr50 myself and it has a bit of piston slap with flat top end speed of about 50kph. i was wondering how much roughly the to bore out the piston? Quote Link to comment Share on other sites More sharing options...
MKD Posted November 24, 2014 Author Share Posted November 24, 2014 Cheers, I think it was $90 for the boring and $45 for the piston kit 0.5 oversize. I couldn't find an actual FR50 piston but the JR50 / LT50 ones are the same. so far it runs ok but its lean as i think its got an air leak somewhere - it does 65kmh at the moment but should get better when it runs richer Quote Link to comment Share on other sites More sharing options...
davejayed Posted November 25, 2014 Share Posted November 25, 2014 thats not a bad price, i might budget for that job next winter. have you checked out the FR50 parts on EBAY? it coming down with original and reproduction parts if your having trouble finding them. the only prob can be 4 weeks to arrive! I've been on the lookout for a donor bike for a while but nothing local has come along. cool build and thanks for the info Quote Link to comment Share on other sites More sharing options...
MKD Posted August 3, 2015 Author Share Posted August 3, 2015 This thing is doing my head in with not starting....so anyone with a fr50 let me know what settings your running (running well) carb settings are at!! Can you post air/fuel mix screw and idle speed screw settings (amount of turns out from hard wound in) then at least i can go from there. So far ive checked and or replaced - coil, condenser, points, plug, plug cap, plug gap, timing, fuel tap, jets, needle, air filter, fuel tubing, tank filter....the list goes on. Carb is it i know it haha Chur. Quote Link to comment Share on other sites More sharing options...
Chunky_t Posted August 5, 2015 Share Posted August 5, 2015 There seems to be a theme with these FR's.. Lol Quote Link to comment Share on other sites More sharing options...
crustywhip Posted August 5, 2015 Share Posted August 5, 2015 I never have troubles. Set the points and she strums. Even built a 80cc a few weeks ago with an undersized piston and one ring. Bike went hard all day. 1 Quote Link to comment Share on other sites More sharing options...
MKD Posted August 5, 2015 Author Share Posted August 5, 2015 Points are set sweet although theyre original so i could maybe replace them. Got it going again, seems it floods pretty easily and have to take out the plug for few kicks and dry it out gefore it'll turn over again. I might just bite the bullet and take it in for a tune... Quote Link to comment Share on other sites More sharing options...
Chunky_t Posted August 5, 2015 Share Posted August 5, 2015 Mine was flooding real bad too, but I noobed out and put the air breather hose for the carb and the fuel hose around the wrong way loool Quote Link to comment Share on other sites More sharing options...
MKD Posted September 1, 2015 Author Share Posted September 1, 2015 Sussed this btw. Effing points...but sorted and starts first kick like a boss on hardly any choke. Finally. Next on the list is the seat. The fa50 seat actually looks pretty cool on it after a random set-if-it-fits but still probably going with the seatbelt brat-style seat...when i get round to it Then tail light... Crustywhip you have dimensions on a chamber for these? Quote Link to comment Share on other sites More sharing options...
TMC Posted September 4, 2015 Share Posted September 4, 2015 i got chamber design and can fab one up, its for more low/middle range tho Quote Link to comment Share on other sites More sharing options...
