yetchh Posted June 29, 2021 Author Share Posted June 29, 2021 Yeah bro, I'm stoked. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 29, 2021 Share Posted June 29, 2021 Hes a GC. I feel like a shitcunt cos I only ring him when I want something. 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted June 29, 2021 Author Share Posted June 29, 2021 That's what happens with friends.. Specially when your lifes full of shit. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 9, 2023 Share Posted September 9, 2023 Lever arm morrie trick is just put thicker fluid in, 30wt I think it was for a firmer road feel Have also seen a tube with adjustable fitting added to connect the two cylinders to give adjustable dampening 2 Quote Link to comment Share on other sites More sharing options...
Tiger Tamer Posted September 10, 2023 Share Posted September 10, 2023 My 64 Hillman Minx lower shock mounts attach to the leaf spring plate. It doesn't seem to cause any problems. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted September 10, 2023 Share Posted September 10, 2023 3 hours ago, Tiger Tamer said: My 64 Hillman Minx lower shock mounts attach to the leaf spring plate. It doesn't seem to cause any problems. My lancer ones too Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 10, 2023 Author Share Posted September 10, 2023 8 hours ago, tortron said: Lever arm morrie trick is just put thicker fluid in, 30wt I think it was for a firmer road feel Have also seen a tube with adjustable fitting added to connect the two cylinders to give adjustable dampening Yeah I've seen that, also read a bit about oil thickness as well. I'll pull them apart and give them a service with 30wt. Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 10, 2023 Author Share Posted September 10, 2023 3 hours ago, Tiger Tamer said: My 64 Hillman Minx lower shock mounts attach to the leaf spring plate. It doesn't seem to cause any problems. 16 minutes ago, bigfoot said: My lancer ones too They do also on my 929 coupe but they are pressed on such a way as to give strength, the kits sold for the mk3 have no gusseting or any strengthening and are just a thinnish extended spring plate to accommodate the bottom shock mount.. For $900 they'd need to be better IMO. 1 Quote Link to comment Share on other sites More sharing options...
