mrsmarty Posted December 26, 2013 Posted December 26, 2013 Plz excuse novvy post on acct of beingafrustratedgirl/inabilitytoreadinstructionsanyway, Currently moving a 4g63t engine across from one ex lancer to another (originally built by motardbiker, has various adds and changes, which I have so diligently and enthusiastically listened to explanations of (just get it going FFS!). Current ecu is a Mitsubishi RVR MD312467, apparently NOT the same as the Evo1 ECU wired in using the ex lancer loom. New ecu I believe is evo3 and has attached loom. Google has been fruitless. Even in German. I'm told. I need a 'colour coded pinout for the rvr ecu' ... Would like to see this thing going BEFORE the newly acquired blackmail Xmas puppy is having its own,,, Thanks in advance Quote
mrsmarty Posted December 27, 2013 Author Posted December 27, 2013 I believe the new ECU is tuned perfectly for the setup, (its a wolf 3d?) and loom supplied with it is possibly the tidiest spaghetti I've ever seen. I think the tuning is the selling point on it? Quote
OSM Garage Posted December 27, 2013 Posted December 27, 2013 Would the only difference between the EVO and RVR be the timing? (CAS vs Trigger wheel?) Quote
fuel Posted December 27, 2013 Posted December 27, 2013 Would the only difference between the EVO and RVR be the timing? (CAS vs Trigger wheel?) Even that doesn't matter, as far as the ECU is concerned they are the same. The CAS is essentially a crank sensor and cam sensor in one as opposed to being split up separate on the later RVR engines. The wiring is the same. Quote
