Firebrand Posted December 21, 2013 Share Posted December 21, 2013 I've owned my 1983 Starion GSR-II for almost 5 years now. This is taken earlier this year: Bought it sight-unseen from Christchurch and drove it back to Wellington. I moved to Dunedin in 2010, so drove it all the way down packed full of gear. Spent the next three years tinkering with it and driving it all around Otago, it was pretty solid and reliable considering 80's, turbo etc. but the paint was flaking badly in places (from a poor respray sometime in the distant past), heaps of play in the steering and it was getting a bit of rust in sills, doors etc. So at the start of 2013, I returned home to Wellington, got a better job and the last couple of months I am finally starting to make some progress on the car. I hauled it into my garage and went over it with a fine toothed comb, noting down every flaw to be fixed and improvement to be made. I ended up with a list of around 160 items! The major ones are a repaint (properly this time),new wheels (probably 15" this time), getting steering sorted, LSD (if I can find one), and just a really good tidy up of everything else. So the tear-down begins : Found a bit of rust so far (mostly in the rear corners), but not as bad as I expected. Paint is flaking off all over the place, it looks way better in the photo than in real life. Pulled off the fenders: I think I've saved about 2kg in weight just from dirt and dust I've removed from underneath panels and other places. Luckily very little rust on either fender, which I am really happy about, as starions usually rust like crazy there. Underneath the fenders looks pretty good too. Just needs a cleanup and a coat of paint. The door in the background of the second photo is rust free and almost ready to go on the car also. discuss here 4 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted April 30, 2014 Author Share Posted April 30, 2014 (edited) So I've been making slow but steady progress, new door is on, rust free and straighter than the previous one. I've repaired both front fenders. Pulled off all intercooler piping, repainted everything and replaced all silicon joiners. New spark plugs & leads, gave engine bay a general tidy up. Replaced the gear shift bushing & changed trans fluid, gearbox feels much tighter now. There's so much more stuff I've forgotten about, but it's getting there. I fixed up a whole lot of surface rust and flaking paint around the rear of the car. I've decided against getting a full repaint for now, I don't have enough money at the moment, and I really want to just get the car back on the road. So today, I put in a new battery, and fired her up for the first time in 6 months, started fine without too much complaining Just need a bit more paint work, mostly in the rear lower fenders, then to reassemble everything. Once ready I'll book it in for a WOF, also needs new tie rod ends (and probably more), and the clutch is engaging with the pedal really close to the floor so I'll get that checked out too. All going to plan it should be ready by the end of May (famous last words!) Edited July 20, 2020 by Firebrand cleaning up broken photobucket images Quote Link to comment Share on other sites More sharing options...
Firebrand Posted July 15, 2014 Author Share Posted July 15, 2014 (edited) Almost back in business. I put on the late model (Widebody) tail lights I imported from japan a couple of years back. Still haven't fixed the dented rear corner properly, but I don't care right now, I just want to drive it... Just a bit more reassembly to do, then in for a WOF, hopefully no major work needed... Also picked up these nice old Clarion speakers (used but still in original box). I only got two, but I have 4 speaker holes to fill, so if anybody has a matching pair let me know: Edited July 20, 2020 by Firebrand cleaning up broken photobucket images 1 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted October 5, 2014 Author Share Posted October 5, 2014 (edited) A few weeks back I ended up buying a complete black interior from a guy in Auckland, I was heading up there for work anyway so it worked out well. My current interior was looking rather tired, so it's definitely an improvement. Over the last couple of weeks I've stripped out most of the old interior and put the new stuff in, not quite finished yet but it's looking good so far: Best thing is the door cards have survived nearly 30 years without someone cutting speaker holes in them: I haven't had time to get the dash swapped over yet, I think it's going to be a mission, but will be worth it, the new one is mint: So just a bit more stuff to do, then time to book it in for a WOF and see what's wrong with it... Edited July 20, 2020 by Firebrand cleaning up broken photobucket images 4 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted October 28, 2014 Author Share Posted October 28, 2014 Went for a WOF today, got a bit of a list to work through but nothing unexpected: I'm going to need a set of rear struts if anyone has any, as well as a Wiper motor and linkages. Most of the other bits should be OK. Quote Link to comment Share on other sites More sharing options...
Firebrand Posted August 3, 2015 Author Share Posted August 3, 2015 (edited) Finally some progress! The starion has a WOF & Rego. I'm picking it up from the garage tomorrow afternoon, and will be able to drive it legally for the first time in 2 years, it's so sad that it has taken me this long. In October last year, I took it in for a WOF inspection, hoping to get it fixed up in time for summer. The list of failed items is in my previous post. The garage replaced the worn steering bits, while I went on a bit of a shopping spree: New rear shocks from Mookeeh in the US Tokico front inserts from Amazon.com New rear brake disks, pads and wheel bearings from Ebay Sway bar bushings (SuperPro) I wasn't 100% sure that the struts would fit, but the rear ones matched up perfectly, slightly shorter to match my springs also: The front ones however caused all kinds of drama. I pulled out one of the old oil shocks, and test fitted a new insert. It fitted the strut, but the gland nut was the wrong size. The factory gland nuts were far too thick for the new inserts. I checked with autolign and they confirmed that the shocks were the right kind, but I tested with another pair of struts (thanks to oldschool member 'dave' from Whangarei), and finally saw the error - one of the Tokicos had the correct nut, and the other (which I had been test fitting with) was too small. After some trial and error autolign came through with a KYB gland nut that would fit the strut, it just needed a spacer to fit the top of the insert. So I got out my grinder & hand files and 'machined' a spacer from the not-fitting nut, which slotted in perfectly for a nice tight fit (here's a shot halfway through - once it was the right diameter I sliced off the plate at the top and ground down to fit, measuring as I went to keep it all flat and smooth): And then installed the inserts: By now I had moved house and given up on the original garage. I rebooked with another place nearer my current house for a new inspection. They said the rear bearings and brake discs didn't need replacing after all, so now I have a spare set of each for the future. All that was needed now was: New clutch master & slave cylinder New drivers side seatbelt Power steering hose remanufactured and reinstalled as it was leaking, and my spare one leaked even worse. Those are now all sorted, and we are ready to go, can't wait for tomorrow Edited July 20, 2020 by Firebrand cleaning up broken photobucket images 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Firebrand Posted November 10, 2015 Author Popular Post Share Posted November 10, 2015 (edited) I drove the Starion for a few weeks once the WOF was done, then headed to Europe for 5 weeks on holiday, and now I'm back again. The new shocks completely transform the car (the original shocks were totally fucked). It's now sitting slightly higher in the back and slightly lower in the front (which looks pretty spot on). The front tyres seem to just be catching the guard lip at full lock so I'll take a look at that when I get a moment. Other wise it's running beautifully. Hopefully I'll be able to get to a couple of meets this summer. Edited July 20, 2020 by Firebrand cleaning up broken photobucket images 11 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted July 26, 2016 Author Share Posted July 26, 2016 (edited) So a word of warning, remember to close your bonnet when you leave the house! Otherwise this happens: Scary as shit when it flies up, had to steer off onto the shoulder of the motorway blind. Felt like a right muppet. I was working on it the night before and just left the bonnet resting closed without latching it on, then got up for work, backed out half asleep without noticing it wasn't properly latched. Surprisingly little damage, the bonnet is fine, and it couldn't get anywhere near the windscreen. The cowling is pretty fucked, you can see in the top photo where the bonnet struts have sheared through the metal. Bonnet has moved back a few cm, I can only just get it latched closed now. This weekend, I'll be pulling the front of the car apart again to see what I can do to fix it. Another couple of dents for the collection. Edited July 20, 2020 by Firebrand cleaning up broken photobucket images 2 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted January 1, 2017 Author Share Posted January 1, 2017 Update time for this guy also. A while after the bonnet incident above, I got down to fixing things. I had to remove all panels etc from the windscreen forward, and ended up with something like this on each side: I'm no panel beater, but I bashed it out as best as I could and used a bit of filler to smooth things out, first time I've done a decent panel repair like this and it took ages to get things looking nice. Here's how it came out - not perfect but not too bad: Threw on some paint from a colour matched spraycan, and polished the shit out of it until it looked half-decent. I have a replacement cowling in my stash so if I ever get the car repainted I'll probably replace this whole section with the fresh one anyway: Also had to straighten up the bonnet hinges, then put everything back together. Then I got a fresh one of these ready for summer cruising: And I also picked up a set of these factory alloys which I may or may not put on, they look pretty decent though, but need a tidy up: 4 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted May 28, 2017 Author Share Posted May 28, 2017 I've been having some issues with overheating under load for a little while now, to the point that I couldn't really drive up any hills or drive under boost. A bit of amateur diagnosis pointed to the issue being a blocked/dead radiator. I'm not surprised, as my current one was put in from a parts car I had six years ago, and it wasn't really in great condition back then. On top of that my fan clutch is totally stuffed. So the only options I had were a second hand radiator off trademe (which was likely to be just as shit as the current one), importing a new radiator and fan clutch from rockauto with no guarantee of quality, or for a similar price, getting a new aluminium radiator & electric fan. So the last option is what I did. It also allowed me to removed the rather sorry clutch fan, saving a bit of drag on the engine, and freeing up some space: I installed the new radiator (it is designed for Nissan S13 Silvia with SR20) , with a little assistance from @ProZac's build thread: It needed a custom bottom bracket which I made from a piece of 90 degree aluminium bar, it's functional and solid, but it looks like crap (I'm terrible at metalwork) so I'll probably redo it sometime. I still need to make some proper top brackets, the current one is just temporary. The top radiator hose is from an 89-90 Pajero v6, which fits pretty well. For the bottom hose, I used a bend cut off a P11 primera hose that had lying around, which is attached to the (shortened) factory hose with a length of 35mm OD aluminium tube. I flared the ends a bit to stop the hoses coming off: The fan is controlled by a Flex-a-lite fan controller via a relay, but the radiator actually has a bung for a screw-in temp switch (the seller said it didn't), so I'll probably swap it out at some stage as it has an ugly probe which fits in the radiator fins, so it looks pretty messy. I got it all together and took it for a bit of a test drive tonight, all is working well so far, temperature was stable when driving or idling, and I also took it right to the top of the hill I live on, which is a pretty decent climb and no dramas at all. The fan switches on nicely and pulls quite a lot of air through. So now I just need to do those top brackets and tidy the wiring up a bit 3 Quote Link to comment Share on other sites More sharing options...
Popular Post Firebrand Posted June 30, 2017 Author Popular Post Share Posted June 30, 2017 When I got home from work tonight, this was waiting in my driveway Came up on Facebook last week, price was right so I grabbed it. It looks like a mess but it's way too good to wreck so it's going to be a long term fix up project. It's an '87 NZ new one, so leather interior, LSD, intercooler etc. 12 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted November 19, 2017 Author Share Posted November 19, 2017 So for the last little while my clutch has been slipping a bit, but it became more of an issue a couple of weekends ago, just revs going up and speed staying the same. So I thought I'd have a go at doing a clutch change for the first time. So i jacked the car up nice and high, removed starter motor, driveshaft, and gearbox. Had a quick check underneath the car and it's looking pretty good, a few spots of surface rust I'll tidy up before I lower it down. old clutch is pretty worn out: so I'll be replacing it with this nice pink one, it's a heavy duty (but still street) one, so should handle a bit more abuse than the old one - kit came with new thrust bearing and the little one that goes in the flywheel also: The inside of the bellhousing is caked with black shit, which I'm guessing is mostly transmission fluid, so I'll clean that up and replace the front gearbox seal also. The flywheel looks OK, but to be on the safe side, and since I don't really want to pull it out for a while I'm going to get it machined before I put it all back together again. 8 Quote Link to comment Share on other sites More sharing options...
Firebrand Posted December 3, 2017 Author Share Posted December 3, 2017 Life got in the way and things took a bit longer than expected, but the new clutch is in, new Main seal is in, new front transmission seal is in. Bellhousing nice and clean. Flywheel machined and new pilot bearing installed, and new thrust bearing. Not many photos - assembly is the reverse of removal etc. I tried my best to torque everything to recommended settings etc. Clutch in place: Everything is back together, and I took her out for a short drive this afternoon. All seems good so far, feels much nicer. Pedal needs a wee bit of adjustment but it's perfectly driveable now. 4 Quote Link to comment Share on other sites More sharing options...
