Goat Posted June 5, 2014 Share Posted June 5, 2014 Good lad Mitch. Good lad. Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 5, 2014 Share Posted June 5, 2014 This thread is filled with terrible ideas. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 5, 2014 Share Posted June 5, 2014 Cheap power is pretty much a terrible idea. Especially when you're converting to a different engine, it's basically completely unrealistic unless you want it to be a total piece of shit. 2 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted June 5, 2014 Share Posted June 5, 2014 How about a VG30DETT mitch? Quote Link to comment Share on other sites More sharing options...
Testament Posted June 5, 2014 Share Posted June 5, 2014 not this thread again. nothing worth doing is cheap and easy. 3 Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 6, 2014 Author Share Posted June 6, 2014 Ok i'm not looking for cheap power... just don't want to break the bank. Might just go with my orignal plans of a sr20det with a t28bb and link... Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 6, 2014 Author Share Posted June 6, 2014 not this thread again. nothing worth doing is cheap and easy. By cheap i was meaning 3kish... Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 6, 2014 Share Posted June 6, 2014 And you want to spend 1.5k on an ecu lol. Just put a rotor back in it and call it job done. 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 6, 2014 Share Posted June 6, 2014 3k is CHEAP Mitch.. And really not possible for anything worthwhile. Break down costs of swap and you easily get past that Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 6, 2014 Author Share Posted June 6, 2014 anyone willing to put money down on this? Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted June 6, 2014 Author Share Posted June 6, 2014 And you want to spend 1.5k on an ecu lol. Just put a rotor back in it and call it job done. Ash much as i would like to put a rotor back in it.. 1.5-2k but buy an engine 6k to rebuild then clutch and gearbox etc... its about 10k for the engine setup on its own.. Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 6, 2014 Share Posted June 6, 2014 You know how you are planning to bodge a piston motor in there? Yea well, you can bodge a rotor too. Quote Link to comment Share on other sites More sharing options...
Testament Posted June 6, 2014 Share Posted June 6, 2014 ok done http://www.trademe.co.nz/motors/car-parts-accessories/chevrolet/engines/auction-736065860.htm 1 Quote Link to comment Share on other sites More sharing options...
Goat Posted June 6, 2014 Share Posted June 6, 2014 Buy an unknown rotor and box off trademe for 1500. Wack a carb on it. Run it on premix. Do some underpowered skids til it pops. 4 Quote Link to comment Share on other sites More sharing options...
Testament Posted June 6, 2014 Share Posted June 6, 2014 a setup that bolts in and works with whatever mounts/driveshaft etc. you have is going to be so much easier than any kind of engine swap. also carby will be easier. you can put an sr/jz/big block in but it will be a bunch of custom fab work and little issues and many skinned knuckles etc. fine if you want to do that. but even the $1500 drillport 12a of questionableness will cost you $3000 in total by the time you get it in there. if you are prepared to spend more, take more time and effort do whatever the heck you like not telling you not to, just telling you its not easy being green. Quote Link to comment Share on other sites More sharing options...
Testament Posted June 6, 2014 Share Posted June 6, 2014 Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 6, 2014 Share Posted June 6, 2014 http://www.trademe.co.nz/motors/car-parts-accessories/mazda/engines/auction-738081321.htm 1 Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 6, 2014 Share Posted June 6, 2014 1uz + auto+ ecu and loom $1300-$1800 or 1uz $800-$1000 gearbox $150-$2000 adapter plate $100-$400 flywheel, clutch , p late $580-$1500 hydro relese bearing $280-$550 2nd hand link $300-$1200 link rechip $150 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 6, 2014 Share Posted June 6, 2014 1uz + auto+ ecu and loom $1300-$1800 or 1uz $800-$1000 gearbox $150-$2000 adapter plate $100-$400 flywheel, clutch , p late $580-$1500 hydro relese bearing $280-$550 2nd hand link $300-$1200 link rechip $150 Throttle cable, radiator? Modified shifter for auto, drive shaft, different sump? Tach and speedo alterations? Random fadteners , cert if going on the street, will clutch master fit? And there will be more Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted June 6, 2014 Share Posted June 6, 2014 yip but all you have posted will be the same regardless of what converstion he goes for unless he gos for a rotor. Quote Link to comment Share on other sites More sharing options...
