piazzanoob's Isuzu piazza
piazzanoob
Hey guys ive got myself a Isuzu piazza as a project car
specs: 1984 2 litre G200z SOHC Engine fuel injected
everything standard
pics of when i got it:
 * old owner painted the two rear alloy wheels and rocker cover silver why? stupid idea :(
bought it in may 2012 with no wof or rego with the intention of a quick 6 month fix up/tidy up job for a wof
but nooo
done a hanger bearing in it for wof had to cut it etc for it to fit
then found out both front and rear windscreens leak and broken window plastic holder so window wouldnt stay up
so then i took it to a mates and washed all the oil from under car and engine bay and ended up putting it in their storage shed
where it still remains
then i figured as windows need to come out and different coloured gaurd cos old one had rust and dent i should paint it and after mucking around for 6 months getting quotes etc i decided to do it myself to do a proper job as it had some rust that needed to be treated in some places.
  • 1 year later...
  • 9 months later...
  • 6 months later...
I thought i better stop being a slacker and update this thread
It was only feb last year that i did some major work on it
It needed the headgasket replaced as it was using and leaking coolent and general tidy up in the engine bay
i had been putting back doing the head gasket for long enough as work etc
untill my boss told me to take some time off as i had a few holiday days owing
so why not do my headgasket right?
then my boss offered for me to chuck it on the hoist and do it
so deal was done
basic headgasket to do and a week to do it easy job right
nah bro!
started off with just removing the head etc
then thought why dont i do the noisy gearbox and leaking steering rack and rack bushes while im at it
so i did that too
then i had a closer look at the block and thought ahh it needs a good lick of paint but do i really need to do it
fuck it lets make this a big job
Things quickly escalated to a big job but owell
also for some odd reason from factory the left hand engine mount bracket is white and the right hand one is black so i gave both a new lick of white paint
also gave the block a lick of VHT black
and sanded down all the other brackets and pulleys etc and painted them while i was at it
now that was quite a long process in itself.
Now to the cylinder head saga
I sent my cylinder head to our local guy we use for a valve grind,plain and clean all sweet
get a phone call later on and he tells me it needs a couple of exhaust valves as there burnt
sweet get some
calls later on
i cant souce any mate what? have you tried STA parts? yup they got none dam
So i gave STA parts a ring to just confirm this and nah we got some just need to get them off our supplier Okaaaay
so i gave my engine guy a ring and told him what i had just been told and all that come out of his mouth was F*ck
this F*ck that little young C*nt from there
so now i know not to let the young fellow there serve me (although i think hes left now)
so next morning the two valve's turn up
and wtf there not exhaust valves there inlet
so i ring them up and get them to send me exhaust valves
now ive recived the right valves and its friday the day its meant to be
out of the workshop and done
the block still out
all the bits are off it still
no gearbox or radiator in
and the cylinder head is still at the shop and not finished
oops
so that day i finish off cleaning and painting parts on the block
and receive the cylinder head back all done.
so theres as far as i got on D day  :doubt:
  • 10 months later...
So now it was week two
And
back at work
And that continued for quite awhile
then i collected the cylinder head
and fitted that on one of my days off while still trying to tidy/paint other bits up.
ONE MONTH LATER.....
I then looked at the intake system on it
And while painting and tidying everything else up on the engine side of things
it would make the whole thing look bad if i just put it back on.
So i then looked at my options to what to do with it.
paint it?
blast it?
polish it?
get it done in vht?
well so i decided to get it bead blasted.
now what next
i needed a paint that would stick to cast Aluminum.
i thought about vht clear but wanted something that would last the heat and time.
so i fucked around and talked to a few people.
 I then ended up going round to a friends place where he painted all his engines in a caprithane paint.
he then offered to do mine free of charge but he would do it when he got time.
A week went by
so i popped round and spend a few hours masking all the bits up.
few weeks later....
I popped round to check for progress
He had brazied up a small piece on the water pipe that had a pin hole
And........
Applied a primer coat on the intake pieces
Mayte check out those masking skills
then a couple weeks after that he rung me and told me he had applied the final coat of paint and it was ready for collection.
but
I had to spend many hours spinning yarns before leaving with the finshed products.
had some trouble uploading the photos the other night due to file sizes too big
but algood now after reducing them online
photos don't really show how great they came out
they have a great sparkle in the right light
and best of all they were just painted in a dirty ol container with a cheap spraygun.
and you would never of guessed.
well
ive had this car sitting around since september last year as went overseas etc
took it in for a wof in december and upon inspection we found rust in the L/R chassis rail and tyres worn as i haven't replaced them since owning the car
so algood with knowing that and still no wof i took it home for it to be repaired.
month goes by so i pull the rear bumper off
and have a look to find it will need a patch welded in
so one long weekend comes and goes then the next i figured i should fix the thing.
so in the shed it goes
so here's the proof of the rust
Then as it turns out the R/H side also has some rust there
so now two patches are required
so in order for us to cut the old steel out the fuel tank needed to be removed
which turned out easier than expected
then the old rusty steel had to be cut out
so this was the L/H side
then R/H sides turn
which ended up in this
And R/H side
I then sprayed some rust converter in the chassis rails to slow down the process of other rust coming through
so made up a patch for each side using some thicker panel steel and originally made from
i also applied some paint to the inside of the patch panel to pervent that from starting rust also
i then cleaned up the edges for the panel to weld in nicely
and my old man got his safety gear ready to weld the patches in as i haven't done enough welding to be good enough yet.
so with the welding getting done a whole lot of smoking also was created
I now suppose you want to see the patches welded in right?
well here we go
so with that being done we both called it a night.
the next day i set about tidying up the patch/welds to make it look less obvious
i then mixed up some body filler to tidy the job a bit more as you would notice the patch with just some paint on it
i then applied some coats of POR15 over the patches to cover them and pervent rust coming back
in the end the patches turn out okay
wasnt 100% happy but that couldnt be helped as the replacement patches ended up being high than all the other steel around it
and i also had some holes still there from where the welder burnt through so had to fill those
but not to worry as you only see that corner if you take your time with a light and take a look.
as i never knew in the first place it had rust there until the wof inspector took a close look in there but he had only noticed the rust on the L/H side and said he couldn't
see any on the right.
So with the rust and the Assembly done the next job would be a wof right?
nah mate
drove it a few times to work and back with no wof etc
Then decided i would do a thing that i had needing to do on it for awhile
which is a good wax and general tidy up of the paint
so i spent one night did that
then another night i went through and buffed all the windows of most of its water spotting etc.
And then shit hit the fan....
it started miss firing on take offs
knew it was the dizzy cap as i had never replaced it and have clean it up a few times too
dropped the cap and rotor off at Bnt so they can get me a new one
and they give me an old piston mazda 323 cap and rotor to try as they looked close
gave the cap and rotor a go and what do you know now constant misfire
took rotor out as someone previously had tried it on their car and fucked the metal retaining tabs
tried out old rotor and new cap and no more misfire
so went back to Bnt too pay for the parts and...
NAH BRO THEIR FREE THEY WERE GOING IN THE BIN ANYWAY.
Like what?
YEAH BRO WE GOT THEM IN AS THEY WERE LISTED FOR OLD SCHOOL MAZDA PISTON ENGINE AND THEIR WRONG.
AND PLUS THEY HAD ALREADY BEEN TRIED ON A VEHICLE AND BEEN WRITTEN OFF.
YEEEEEAH FREE PARTS!.
Then drove it to work another day after this misfire was sorted and then drive it home after work
and notice the exhaust tone is abit louder
so have a quick look underneath and can feel a leak
pop in back in the shed and place it on some axle stands and find this
The whole exhaust on this thing is getting abit past its used by date now...
second bit ive had to patch up now
got the old man on the welder again to patch it up
done
and made a new exhaust gasket too as old one was fucked and some newish bolts too as old ones were rusty n shit.
yeeeeah
soo with the exhaust and rust done the next thing on the job was the tyres
which started with 4 new kumho's
got some mad camber going on
And while i did the tires
A magic wof inspection sheet and label appeared on my dash
nothing was wrong i guess...
so with a wof and rego now she gets used a bit
Not just a show pony mayte
1 ton load of topsoil
still pulls hard for what it is
probably because the trailer is the same year as the car with the same color combo
  • Like 7
