j.e.d. Posted February 1, 2021 Report Share Posted February 1, 2021 yea absolutely man, tbh I never knew it was like that til he mentioned it so as much as he's not complaining I'll be applying some gap filler at the same time as the garage gets rearranged 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 1, 2021 Report Share Posted February 1, 2021 Chuck a wee supply fan in to his room if you can, or garage extract fan. /both 2 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted August 23, 2021 Report Share Posted August 23, 2021 And a little gal waits…. 3 Quote Link to comment Share on other sites More sharing options...
spac3 Posted July 10 Report Share Posted July 10 Hi mate Is it easy to flip the shackles? Mine are facing the wrong way. Wanting to get them back correct way so it drops the rear slightly Any info or step by step way to flip would be appreciated Sam @j.e.d. Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted July 11 Report Share Posted July 11 15 hours ago, spac3 said: Hi mate Is it easy to flip the shackles? Mine are facing the wrong way. Wanting to get them back correct way so it drops the rear slightly Any info or step by step way to flip would be appreciated Sam @j.e.d. Hey man, can’t remember an exact process unless I wrote it in a post.. I used a short crowbar between the shackle mounts of the body and leaf spring and levered them back, just can’t remember if I needed to drop the nuts off the bottom of the shock to give more range of movement. It wasn’t a tricky process at all though, just gotta jack it high enough to give the crowbar room to rotate as you need good leverage. My crowbar is only 600-700mm long. Hope that helps Quote Link to comment Share on other sites More sharing options...
