BlownCorona Posted July 15, 2013 Author Share Posted July 15, 2013 lol no question. i only asked if it was the problem, because i saw the flash only once (and then that runner didnt spit again) and the other runners that were spitting displayed no visible flash. might just be positioning of the vac leak, who knows. other question is, why the fire on the wrong side of the valve? does leaned out mixture caused by a vac leak ever ignite on a hot valve? never had any issues like this with the webber dd i just pulled of it, so id think the valves and sealing are okay Quote Link to comment Share on other sites More sharing options...
KIRK Posted July 15, 2013 Share Posted July 15, 2013 lean = slow burn = may still be burning when intake opens again and can ignite your fresh charge. or something like that I think Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted July 15, 2013 Share Posted July 15, 2013 Check your timing please and fix all vaccum leaks before attempting any carb tuning. Thanks 1 Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 15, 2013 Share Posted July 15, 2013 . Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 15, 2013 Share Posted July 15, 2013 ive had a lot of old (87-90) gsxr 750s and 1100s and they all ran like shit and over fuelled with out the factory airbox. you can put filters on them all and it will still run like shit.you need to find good filters that breath well and tune it with them on. these k&n filters are the best I personaly used 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 15, 2013 Author Share Posted July 15, 2013 all real good info, timing is perfect, first thing i did, and yes, no more tuning untill vac leaks are sorted, ive had my heart set on velocity stacks for ages, so ill to my best to tune with no filters, but if i end up needing them ill need them, but most setups i see on the net run no filters succesfully. tuning is the part i enjoy most anywa Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 15, 2013 Share Posted July 15, 2013 Yea you don't need filters it is an urban/internet myth, you can easily tune without them. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 17, 2013 Author Share Posted July 17, 2013 so it looks as if it was indeed a vacleak, pulled the manifold tonight and discoverd many, welded them all up, 1st manifold is sweet as, perfect. 2nd manifold however, has bowed slightly after being welded so although the maifold is sealed, theres probably a worse leak at the flange now. is there ANY way that i can get it back straight? zero luck Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 17, 2013 Share Posted July 17, 2013 With a linisher after you get it good with a vice and brute strength. Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 17, 2013 Share Posted July 17, 2013 ive seen a few of them bow including my own, just bolt it up and it will be sweet, as long as it doesnt leak when off the car it shouldnt when on the car Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 17, 2013 Author Share Posted July 17, 2013 ive bolted it up, and it JUST doenst seal, what are the implications of running say two gaskets? or another idea was crank it up hard as fuck on my spare/mock up heat, and heat it alot with the blow torch, would that make it worse or would it re temper it?? Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 17, 2013 Share Posted July 17, 2013 It could work but a linisher is you best bet. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 17, 2013 Share Posted July 17, 2013 Maaaaaaaaaaaaaaaaaaaaaaaaaaaate, tap it with a hammer/get them all planed flat. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 17, 2013 Author Share Posted July 17, 2013 i would really like not not remove any material, because (unlike my previous post) they are actually all the same thickness, and since they fit together on the same side of the engine, clamp up with the same force. that said, if i need to, i need to. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 17, 2013 Share Posted July 17, 2013 Just make packers. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 17, 2013 Share Posted July 17, 2013 Just make packers. Fudge, am I right? Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 17, 2013 Share Posted July 17, 2013 Indeed. Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 17, 2013 Share Posted July 17, 2013 it must be super bowed if its still bent when bolted Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 17, 2013 Author Share Posted July 17, 2013 its possible, because i had to weld a leak in the middle of the two runners, though it occurs to me that it may have been snagging on something. ill have a look tomorrow, but im pretty sure it bowed. Quote Link to comment Share on other sites More sharing options...
Benno Posted July 17, 2013 Share Posted July 17, 2013 Obviously not a good solution if its a serious bow, but would giving it a smear of some silicon gasket sealer do any harm? Quote Link to comment Share on other sites More sharing options...
