Smray's 1970 MK1 Escort Project
smray
Here's my Mk1 Escort, I have owned it for a couple of weeks, and the plan is to get it back on the road for summer,
It's running the 1600 pinto ohc with 2l cam and carby, and standard escort box.
So far I have stripped out the seats, wire brushed and painted passenger's footwell, fitted drivers side mirror, replaced the back brake shoes, flushed the cooling system, adjusted hand brake, hooked up vacuum advance for the dizzy.
//oldschool.co.nz/index.php?/topic/38213-smrays-1970-mk1-escort-project/
Here's a photo of the engine bay for anyone who's interested
I also got the tacho mounted and wired in, and the fire extinguisher, and fixed the hole in the boot but forgot to take a photo of that.
Been a while since I updated this,
Bought some high temp paint, so painted the back drums while I had the wheels off
Polished the lip on the wheels
Painted the manifold while I had it off to replace gaskets
Flange which had exhaust leak
Chopped the exhaust and welded a flexy join in:
9084180584_b1695cf1c2.jpg[
Exhaust back on the car
Took it in for a tune, to find out why it wasn't running right, needed new points and condenser.
Pulled the thermostat housing to check the thermostat, cause the auto choke was coming off to early, and found a crack in the thermostat housing so that had to go, also the thermostat was nowhere to be seen.
Ordered a new thermostat housing, but couldn't find a thermostat clip in NZ so made one,
I could only get a cortina housing which meant the top hose had to be modified, planning on running an electric fan anyway so put in a water temp adaptor to join two hoses
work in progress shot of covering back panels, I still need to take some of the finished panels, and the one door card that I have made so far.
Also have electric fan which I need to finish wiring and mounting.
I'm sure there's some stuff I've missed as well
  • 1 year later...
I probably should get better at updating this, it's been nearly two years. 17926702270_c73d924553_k.jpg20150502_160641
Currently this is how it looks, but it's soon gonna change again. It's geting new flares, a front air dam, and possibly rear ducktail spoiler
17268104665_c9d71981ac_z.jpg20141016_120907
16647884383_fa3665ea17_z.jpg20141016_122152
Been about a year since I painted it, pretty much got a bare bog respray.
15740509148_8ef82c48e4_z.jpgIMG_20140421_160556
