Prozac's OTHER Starion of awesomeness
Guest camo_78
I've played with them a bit, the specs tell you 40-50 amps under load, but I've seen them draw more than that under full load racing conditions.
The rack I've mounted to the staz I've actually opened up an cut the inner seal off, converting it to a non-assisted rack. This is just for easyness of getting things up and running, the car definitely needs power steering. Electro-hydraulic is an idea I toyed with too, but an engine driven pump is still smaller and weighs less. Will mount one down where the alternator was, keeping it out of the way, will make lines easy to run aswell.
3rd gen MR2's have an even better electric psteer pump, with integrated electrics. Give them a speed signal, and they'll vary their assist pressure. Alot of GM stuff from that era also has nice electric powersteer pumps, also with an integrated reservoir that looks quite a bit nicer than the 2nd gen MR2 ones.
  • 3 years later...
