mikey Posted March 6, 2013 Share Posted March 6, 2013 Can someone tell me what the shit? My booster has been rebuilt and now the first inch of travel is really easy to press and has no feedback and almost locks up the front wheels. If you try and brake harder the pedal goes mega hard, like there's no boost at all. If you disconnect the vacum line everything works as you'd expect and it's all peachy, albeit a bit of hard work for this office worker's delicate feet. This is on the 240z. It has a 15/16th master, R32 GTR four pot front callipers and factory drums in the rear. YAY! Quote Link to comment Share on other sites More sharing options...
fuel Posted March 6, 2013 Share Posted March 6, 2013 no restrictor in the vacuum line - it's being over-boosted. Same thing happened when 10-five did the RB swap into his 260C Quote Link to comment Share on other sites More sharing options...
mikey Posted March 6, 2013 Author Share Posted March 6, 2013 Ahhhhh, this is possible I guess. It's got the original check valve from the 240z. Can I make a restrictor out of some round with a 2mm hole drilled in it or sommin and put it inline with my valve? Quote Link to comment Share on other sites More sharing options...
fuel Posted March 6, 2013 Share Posted March 6, 2013 get some vice grips on a rubber line and see how much restriction it needs? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted March 6, 2013 Share Posted March 6, 2013 Brake line clamp and slowly crank it up until you get the pedal you like. Then make a restrictor to suit. Quote Link to comment Share on other sites More sharing options...
mikey Posted March 6, 2013 Author Share Posted March 6, 2013 Oh good stuff. I shall try these things and report back. YAY! Quote Link to comment Share on other sites More sharing options...
mjrstar Posted March 6, 2013 Share Posted March 6, 2013 Check rod freeplay between booster and master cylinder. Quote Link to comment Share on other sites More sharing options...
DJZ Posted March 6, 2013 Share Posted March 6, 2013 Waup waup, possibly your reaction disc has fallen out. http://forums.hybridz.org/topic/69706-reaction-disk-pictures-and-walkthrough/ Quote Link to comment Share on other sites More sharing options...
mikey Posted March 6, 2013 Author Share Posted March 6, 2013 Waup waup, possibly your reaction disc has fallen out. http://forums.hybrid...nd-walkthrough/ I was pretty careful with this when i first set it up, but I'll double check that little blighter. Quote Link to comment Share on other sites More sharing options...
DJZ Posted March 6, 2013 Share Posted March 6, 2013 Got the check valve round the right way? Or as said above adjust the master cylinder push rod, it's pretty easy to do. I glued the reaction disc onto my push rod after losing one inside the booster. Quote Link to comment Share on other sites More sharing options...
mikey Posted March 6, 2013 Author Share Posted March 6, 2013 I pissed around with the push rod heaps last time getting it just right, and it all seems mint without the vacuum line so I think it's OK. Will double check that stuff thou. Am going to Hampton Downs on Saturday so would quite like to have it sussed for that. Quote Link to comment Share on other sites More sharing options...
Guest mikey Posted April 2, 2013 Share Posted April 2, 2013 The winner is.... DJZ. I had no reaction disc, the peeps who rebuilt the booster must've tossed it as there wasn't one inside the booster either. I made one out of reinforced rubber, it's 5mm thick. Factory ones are 5.5mm I believe. I have no idea whether it's the correct hardness or how durable it'll prove to be. BUT, dem brakes are mint! Never been better (since I've owned it). 1 Quote Link to comment Share on other sites More sharing options...
