kyteler Posted January 12, 2015 Share Posted January 12, 2015 Mate. Put the G7 in, get those triples on it. Beauuuuutiful. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted January 12, 2015 Author Share Posted January 12, 2015 Mate. Put the G7 in, get those triples on it. Beauuuuutiful. Would it perform alright though? I though the Vauxhall was a swap because the original engines were rather shit but I have never driven a G7. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 13, 2015 Share Posted January 13, 2015 It's never going to be a monster but it's supposed to be a cruiser anyway, right? Most only ended up with 202's and the like due to the original engine dying for whatever reason and it being cheaper to get a crappy old 202 to put in. The G7 was what got used in the S54 GT-B's mate. 127hp with triple webers or just over a hunge with the old single in the S54 GT-A's. They obviously won't pull the Gloria along as quickly as they would a Skyline but it'd do alright. ..and it's not Vauxhall, so that's ALWAYS a better option. Quote Link to comment Share on other sites More sharing options...
hr31gts-x Posted January 13, 2015 Share Posted January 13, 2015 Hey dont know if you seen them or not but there is couple of these down at smash palace in horopito, there rusty as but think one may have a motor in it still. may have more parts in the many parts sheds they have too. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted January 14, 2015 Author Share Posted January 14, 2015 It's never going to be a monster but it's supposed to be a cruiser anyway, right? Most only ended up with 202's and the like due to the original engine dying for whatever reason and it being cheaper to get a crappy old 202 to put in. The G7 was what got used in the S54 GT-B's mate. 127hp with triple webers or just over a hunge with the old single in the S54 GT-A's. They obviously won't pull the Gloria along as quickly as they would a Skyline but it'd do alright. ..and it's not Vauxhall, so that's ALWAYS a better option. Yea suppose to be a cruiser but I would like to be able to thrash the tits off it too and actually go places. Im fairly convinced buying it is a good idea, even just to hold onto it for a bit. Quote Link to comment Share on other sites More sharing options...
19661968B200Gloria Posted June 28, 2015 Share Posted June 28, 2015 Hi would you sell me one of your key blanks, or both of them? Also have you got a spare rear bumper over-rider, for the drivers side? Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 16, 2017 Share Posted July 16, 2017 I never did get that key blank for my S21. *sniff* Good work on getting stuck into this after your brother though man and if the offer still exists then I'm still keen but if not then such is, I'd probably hoard spares too, (oh wait, i do) lerl. Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 16, 2017 Share Posted July 16, 2017 11 hours ago, kyteler said: I never did get that key blank for my S21. *sniff* Good work on getting stuck into this after your brother though man and if the offer still exists then I'm still keen but if not then such is, I'd probably hoard spares too, (oh wait, i do) lerl. Cheers bro. Ive worked on this few times before owning it. I fixed all the rust in the doors! Yup i saw that he offered you one. Ill see how many ive got. The current one is slightly bent/about to break so i plan using one to to be cut. Id also like to keep a spare for the new one i get cut soon. If there's a 3rd blank. Its all yours. Will confirm tonight Cheers Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 17, 2017 Share Posted July 17, 2017 Perhaps a holden 202 radiator or triumph tc might would in that car same sort of engine size etc alloy radiators are not the best for cast iron engines as it causes electrolysis as two different metals but is fine if you plan on servicing your cooling system more regularly but I'm sure you already knew that 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 17, 2017 Share Posted July 17, 2017 Cheers mate. Radiator is a 600widex400high 57mm deep. Spoke to a guy at trevor french radiators in otahuhu n he said 550 including for it to be re cored with a 4 core hence the thickness. As much as id like to keep it it seems steep. Mx5 radiators are the exact size with the inlet n outlet on same side. As with subaru foresters. Would one of these work? Or does it need to be bigger considering engine is a 3.3 straight 6 Can buy replacement stock radiators for 130. Cheers Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 19, 2017 Share Posted July 19, 2017 On 18/07/2017 at 08:49, Matteybean said: Cheers mate. Radiator is a 600widex400high 57mm deep. Spoke to a guy at trevor french radiators in otahuhu n he said 550 including for it to be re cored with a 4 core hence the thickness. As much as id like to keep it it seems steep. Mx5 radiators are the exact size with the inlet n outlet on same side. As with subaru foresters. Would one of these work? Or does it need to be bigger considering engine is a 3.3 straight 6 Can buy replacement stock radiators for 130. Cheers A mx5 and Subaru one most likely won't have a big enough core as only running a small 4 cylinder plus both are all alloy engine which displaces the heat quicker. https://www.trademe.co.nz/1369952269 ^^ that's a hq Holden one but a v8 radiator size is a bit bigger overall but might fit as a Holden 202 is also a 3.3litre so a 6cylinder rad might fit. @chrisR might let you test fit his 1 tonner rad if you think it might work. Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 19, 2017 Share Posted July 19, 2017 1 hour ago, piazzanoob said: A mx5 and Subaru one most likely won't have a big enough core as only running a small 4 cylinder plus both are all alloy engine which displaces the heat quicker. https://www.trademe.co.nz/1369952269 ^^ that's a hq Holden one but a v8 radiator size is a bit bigger overall but might fit as a Holden 202 is also a 3.3litre so a 6cylinder rad might fit. @chrisR might let you test fit his 1 tonner rad if you think it might work. Cheers mate. Did more research n found yeah i need a 3/4 row out of a v8. Will keep an eye out for a good deal otherwise hopefully this stop leak does the job Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted July 20, 2017 Author Share Posted July 20, 2017 On 7/17/2017 at 09:25, Matteybean said: Cheers bro. Ive worked on this few times before owning it. I fixed all the rust in the doors! Yup i saw that he offered you one. Ill see how many ive got. The current one is slightly bent/about to break so i plan using one to to be cut. Id also like to keep a spare for the new one i get cut soon. If there's a 3rd blank. Its all yours. Will confirm tonight Cheers There's two spare blanks. Spare blanks are pretty soft metal so only real good for show plus ones very slightly bent. Get a generic key cut and one of the spares cut for show if you want. Send other to kyteler if if your keen. Without this man you would have no interior door handle on drivers side lol. Unless it was someone else who hooked me up with that.. either way send it haha 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 20, 2017 Share Posted July 20, 2017 1 minute ago, dave123456789 said: There's two spare blanks. Spare blanks are pretty soft metal so only real good for show plus ones very slightly bent. Get a generic key cut and one of the spares cut for show if you want. Send other to kyteler if if your keen. Without this man you would have no interior door handle on drivers side lol. Yup theres two spares. Drivers interior door handle is pretty important. @kyteler PM me your address mate ill send one down to you this weekend. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 20, 2017 Share Posted July 20, 2017 I don't remember doing that but anything is possible. I guess it could have been solidstripe? Like I said though, I understand if you don't want to part with them. I tell you what. I'll talk to my brother and see if he can CNC me a key based off my current one. I've tried to get a key like mine but they're a weird setup and no cunt has a blank anymore and as dave says they're soft as fuck which is why i need a new one. It scares me turning mine in the ignition, hah. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted July 20, 2017 Author Share Posted July 20, 2017 Just now, kyteler said: I don't remember doing that but anything is possible. I guess it could have been solidstripe? Like I said though, I understand if you don't want to part with them. I tell you what. I'll talk to my brother and see if he can CNC me a key based off my current one. I've tried to get a key like mine but they're a weird setup and no cunt has a blank anymore and as dave says they're soft as fuck which is why i need a new one. It scares me turning mine in the ignition, hah. It would have been 5 or 6 years so who knows. Maybe solidstripe or stevemax who knows. I thought about trying to make a new one but never pursued it. There is also a pile of already cut prince keys which don't even fit this car I was going to try fill back out somehow and recut. Quote Link to comment Share on other sites More sharing options...
kicker Posted July 23, 2017 Share Posted July 23, 2017 Sweet whip man. I'm gonna say nay to the roofrack, maybe something lower profile with some curves but with such sweet styling already I wouldn't run one unless I was using it to cart something. 2 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 23, 2017 Share Posted July 23, 2017 Cheers mate. Yeah shes got some sweet curves. Im 50/50 with the rack at the mo. See if it grows on me Quote Link to comment Share on other sites More sharing options...
1963 AP5 Posted July 23, 2017 Share Posted July 23, 2017 Not sure about that particular roof rack, looks mighty tall. On your starter issues, have you tried giving it a good clout when it refuses to turn over? Sometimes the brushes can stick in the holders. A bash can make them spring into place again. You probably tried this already but I thought it would be worth mentioning. 1 Quote Link to comment Share on other sites More sharing options...
Matteybean Posted July 23, 2017 Share Posted July 23, 2017 19 minutes ago, 1963 AP5 said: Not sure about that particular roof rack, looks mighty tall. On your starter issues, have you tried giving it a good clout when it refuses to turn over? Sometimes the brushes can stick in the holders. A bash can make them spring into place again. You probably tried this already but I thought it would be worth mentioning. Yeah mate did that before i took apart - all the spring mechanisms and brushes were in good working order. The problem i think i have is "heat soak" which is the exhaust too close to starter heating it up past what its suppose to causing it to not work. Will confirm once i try tomorrow. Fingers crossed. Maybe replace earth wire but will check resistance tomorrow. Cheers mate 1 Quote Link to comment Share on other sites More sharing options...
