1969 Nissan Patrol G60
robs30m
  • Replies 116
  • robs30m
    110
removed the rest of the bolt on bits and pieces. oil filter and housing, dizzy , oil pressure switch etc. original color was the same as the rocker cover. might try get close to that. second picture shows the engine mounts, beefy! There is two the same at the back of the block. shows why when you rev the old girl the whole truck rocks lol
20130715_225842-816692592_zpsd368152f.jp
got into it and cleaned and scrubbed the engine block. alot of wire brushing and
degreasing ! prepared and then sprayed it. liking it alot. its a heat paint with
ceramics added. Won't cure properly till its heated. bolted a few bits back up.
20130721_1835441509714323_zps5305aaa6.jp
20130721_1836351057485750_zps19753c68.jp
had a litte trouble remembering how rear shoes fit. lucky I have the pdf msnual. this the correct orientation, picture is of driver side rear. its makes sense now I look at it. stronger spring is at the bottom as its carrying the weight of the shoes. the gap at the leading edge of each shoe allows brake dust to drop off and to the bottom and disperse as the drum rotates.
