OldNathans MX41 Mark II Grande talkie talkie
OldNathan
  • Replies 90
Awhile back when I was googling about these engines, I think (from memory) people were saying the bell housing bolt pattern on the block is the same as a 1UZ. You've played with 1UZs can you confirm they are the same? Would make aftermarket bell housings easy if they are...
Yeah the biggest thing I have learnt now is unless its a general consensus its best to try it lol. So I did. The 1UZ is almost a comparable fit to the JZ one. Obviously the starter hole is in the wrong place but more bolt holes line up. The JZ is a slightly better match to the actual bellhousing shape. Ive added pictures to the build thread.
Does anyone have a mid shift shifter for an R154? Looks like the one on the box I have will sit a little to far foward to my liking. Also after a very low ratio F series LSD. Like 3.2 ish?
Need to go to G series to have any chance of finding ratios close to that.
3.7 is the nearest ratio I know of in F series and it's friggen hens teeth.
