Dirty_Safari Posted October 15, 2013 Share Posted October 15, 2013 Nice colour, well done sir. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted October 28, 2013 Share Posted October 28, 2013 Ultimately the final decision is yours. But I'd leave the black plates on there. Every time. 1 Quote Link to comment Share on other sites More sharing options...
beachlander Posted October 28, 2013 Share Posted October 28, 2013 Black plates for sure 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 28, 2013 Share Posted October 28, 2013 You wont be able to put the black plates back on. The rule that lets you put them on is for re-registering the car and states they must be the last plates used on the vehicle. I wouldn't ever remove black plates from a car, they are special magical things. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 28, 2013 Share Posted October 28, 2013 My old man purchased the old plates as p plates so he has a set of white ones and a set of black. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted October 28, 2013 Share Posted October 28, 2013 Plates did him a deal too, 50% off or somesuch Quote Link to comment Share on other sites More sharing options...
toy-mota Posted October 28, 2013 Author Share Posted October 28, 2013 the car is still under the black plates at the moment,i like them both,bit over a bugger i carnt swap them back if i do change them,mite have to think about it for a while. Quote Link to comment Share on other sites More sharing options...
Mattt Posted December 23, 2013 Share Posted December 23, 2013 I'd replace the points and condensor, check for vacuum leaks and make sure the pcv valve isn't blocked. Also check that the plugs and leads are sweet. It's had a recon on the carby so it shouldn't be an issue. Also check the condition of the earth to the engine. They can cause mega issues if they're toast. Quote Link to comment Share on other sites More sharing options...
D1RTY6 Posted August 13, 2014 Share Posted August 13, 2014 Pretty sure it was this car i saw in the weekend in Goon?? Looks fucking awesome rolling man! 1 Quote Link to comment Share on other sites More sharing options...
Maggy Posted October 19, 2014 Share Posted October 19, 2014 this thing was awesome to be smashing up hanmer gravel roads in. awesome to put a face to a car man 1 Quote Link to comment Share on other sites More sharing options...
Maglizard Posted November 4, 2014 Share Posted November 4, 2014 Great car man! Are you running shorter shocks in the rear? I'm lowering my MS65 and need tips to what shocks i can use in the rear with cut springs. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
toy-mota Posted November 14, 2014 Author Share Posted November 14, 2014 yup i used shorter shocks in the rear,i just took my factory shocks into BNT and told them how much lower i was going.i think they may have been VW Kombie shocks, also i got my springs compressed Quote Link to comment Share on other sites More sharing options...
phatt20 Posted December 12, 2014 Share Posted December 12, 2014 loving the attention to detail, nice work. 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 5, 2015 Share Posted July 5, 2015 Making your 2J look like a 3T is an awesome idea! You've pulled it off really well. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 6, 2015 Share Posted July 6, 2015 really excited to see how this motor looks in your car. So keen to replicate intake at some point Quote Link to comment Share on other sites More sharing options...
Snoozin Posted July 6, 2015 Share Posted July 6, 2015 Making your 2J look like a 3T is an awesome idea! You've pulled it off really well. Like a 3M you mean? I also reckon it looks spectacular, and it should sound wild too! Quote Link to comment Share on other sites More sharing options...
sheepers Posted July 6, 2015 Share Posted July 6, 2015 yea im also a big fan of the 3M look a like. it looks like an M but its not a huge pile of shit. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 22, 2016 Share Posted May 22, 2016 I don't really know what suggest here..... my motor literally sat in the perfect place and mounts were made maybe there is more difference between our chassis than I thought? what sump you running? Quote Link to comment Share on other sites More sharing options...
toy-mota Posted May 22, 2016 Author Share Posted May 22, 2016 It looks like your crossmember is narrower than mine,also mine doesn't have the holes in it so could be different i have a ms112 front swaybar on the way as they sit down lower,so should clear the pulley better im running a rear sump with OS member MATTTS notched oil pan Quote Link to comment Share on other sites More sharing options...
Valiant Posted May 22, 2016 Share Posted May 22, 2016 Can you, Easily move the motor back 25mm? Lower the sway bar? Remove the sway bar? Quote Link to comment Share on other sites More sharing options...
