  • Replies 79
Thought i should push this out of the garage for a quick wash .
Shit it looks good.
After a year sitting on stands and no front end . I finally get to see it how it was 4 odd years ago.
I have bought a link g4+ storm ecu.just need a fuel reg and pump now and should get her going very soon
  • 4 months later...
Well she finally runs. 6 years in the making.
Started first pop and sounds awesome!
Still needs to be road tuned as it has a flat spot at 2500rpm and cuts out, but
IT RUNS!!!
A few small issues to fix and should be all go for cert.
The 1st day of spring ,sunny and warm and im in the garage under the car fixing my exhaust as the last time i took it out it ripped my automatic gate rail clean out of the ground. Have fixed the rail and got stuck in today shifting the exhaust higher ,got an extra 30mm out of it. Took it for a test and all is good now .
Next issue is the front sits lower. It sat fine with the old motor/box , but maybe a 2jz/w57 combo is heavier. I had originally got the springs compressed. I have another set of factory springs ,but with little budget at the moment im thinking of cutting them. Should be stiffer than compressing. Only problem is i havnt chopped springs before,it needs to be 25mm higher.How do you know how many coils to remove?
I also have more camber than I remember, are ms112 lower arms longer?
Disscussion thread here
  • 3 months later...
the lasting outing in the crown i had fuel issues’s . I had over 1/2 tank and it was just surging. So bit the bullet and cut my spare tank apart and have fitted a in tank pump and baffles.
pump assembly is from a Subaru with an aftermarket DW200 pump fitted. Modified the assembly to fit the crown tank,things are getting tight. Also had to machine up a extension on my pickup/filter so it sat at the bottom of the tank
This may have also been causing fueling problems . This is the factory pickup from inside the tank. The pipe is about 12mm ID but right at the end its flattened off and is less that 1/2 the size ,glad its gone now
With installing itbs, i needed to run an aircleaner. Im not a fan of socks and the SQ Eng trumpets dont allow individual socks to be fitted. Keeping with the theme of the factory look. I made an aircleaner. I copied the original 4m box in the way that it seals and the lid clips on. Although large ,it lets me keep the trumpets.
All thought out and made by myself, with hand tools,shrinker/stretcher and a beadroller.
Can anyone guess what the lid was made from?
Managed to get the crown to muscle car madness in Rangiora on the Saturday. Alot of interest from people .
(Only photo i have from the show which i found on FB, if any one got any send them through)
Also chopped up my factory JDM ms75 tash to fit in a speedhut 3 3/8 Electrial speedo. Easy to install and wire up. Doesnt look to far out of place .
  • 8 months later...
So i have my wedding coming up ,start of next year.that means the crown is the main wedding car. I cleaned up and painted my ms53 steelies, added some rather large 215/75 maxxis whitewalls and refurbing the factory supersaloon hubcaps, even going to put gold resin back into the crown emblem were its missing.
still not legal or tuned ...... maybe next year will be the year
Got the old girl out to the december OS meet. Was great catching up and meeting new people
thanks to cool cruising photography for these pics
  • 3 months later...
  • 4 months later...
After 6 years of it being off the road its finally certed ,wof and reg .
so stoked to have reached this point now its off to the dyno then i can enjoy it
I put the crown on the dyno at SAS here in chch . To get the motor running right as it was only road tuned . 2 hours on the hub dyno and i got this...
200hp aircleaner on
226hp aircleaner off
im happy with it, i wasnt chasing HP , its just a big jap cruiser with abit of power and noise
vid below
https://youtu.be/cMzoZRc_0OM
  • 4 years later...
