Marsh Posted January 18, 2013 Share Posted January 18, 2013 Hi all Have bought a 4age to put into my start and also got a set of sidedraft dellortos for it. What is the best way to block off the injector holes into the head? Was thinking either tapping and screwing in bolts or using something like sellys kneed it or quik steel Quote Link to comment Share on other sites More sharing options...
evil_si Posted January 18, 2013 Share Posted January 18, 2013 Could use devcon, Or use frost plugs Quote Link to comment Share on other sites More sharing options...
DJZ Posted January 18, 2013 Share Posted January 18, 2013 I can't recall what a 4AGE head looks like but there are these things on Trademe, way more expensive that using frost plugs as suggested though. http://www.trademe.co.nz/motors/car-parts-accessories/mazda/engines/auction-552216496.htm Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 18, 2013 Share Posted January 18, 2013 Get someone to machine up some aluminum plugs to be a press fit into injector holes. Use loctite/ gasket sealer if you feel the need. Wack in with a mallet. Only good thing about those Tm ones is that they can be removed easy. ( you could always drill and tap aluminum plugs and use slide hammer to remove if desired Quote Link to comment Share on other sites More sharing options...
Marsh Posted January 19, 2013 Author Share Posted January 19, 2013 Cheers guys. Frost plugs sound like the easiest way to go for me. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 19, 2013 Share Posted January 19, 2013 On a side note, should run these carbs Quote Link to comment Share on other sites More sharing options...
Marsh Posted January 19, 2013 Author Share Posted January 19, 2013 What carbs are those ones?? Not that I need to collect more pieces... Quote Link to comment Share on other sites More sharing options...
Corbie Posted January 19, 2013 Share Posted January 19, 2013 look like HIF type SUs Quote Link to comment Share on other sites More sharing options...
Llama Posted January 19, 2013 Share Posted January 19, 2013 Naw the float bowls are to the side, be HS SUs, probably HS4s. Why anyone would do such a thing is beyond me though... Quote Link to comment Share on other sites More sharing options...
phatt20 Posted January 19, 2013 Share Posted January 19, 2013 for the love of god dont put su's on anything you want to go hard, if you want to use a cv type carb get some bike carbs. Quote Link to comment Share on other sites More sharing options...
Shandangles Posted January 21, 2013 Share Posted January 21, 2013 use need-it, works a treat and is quick and easy. Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 21, 2013 Share Posted January 21, 2013 yuck! thats my car, yeah dont put SUs on anything. i got em free and needed to get the car running, i swear FYI, ignition is stock dizzy and Hyperpak CDI unit. super easy to install, you can see the 'loom' coming through the firewall on exhaust side i made alloy plugs and knocked them into the injector holes Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 21, 2013 Share Posted January 21, 2013 In the past i have just tapped the injector holes and wound in some Grub Screws Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted January 22, 2013 Share Posted January 22, 2013 Frost plugs are good if you ever want to use the head to run injection again because you can just knock them out and place injectors back in. Quote Link to comment Share on other sites More sharing options...
