Whitefoxx's 1973 Ke20 Corolla 2Door Sedan
whitefoxxx
I drove the car home when i brought it and is pretty complete but she ran a bearing on the drive. Car has a 5k twin carbs which is getting rebuilt, body of the car is pretty straight and overall good nick only small repairs needed (some rust and couple of small dents and chips) should come up sweet tho
Just a wee update, got the motor apart today, the numpty who did the last rebuild didn't put in the bigend bearings correctly resulting in number 1 spinning up and number 2 about to. just a couple of pictures number one is the flattened one because i had to carfuly pry it off as it was stuck, the crank is still salvageable will get away with a 5thou grind id say.
Am going to do a full rebuild, send everything away to get cleaned up and then put new bearing rings and gaskets in :)
  • 5 months later...
