scooters Posted February 3, 2018 Share Posted February 3, 2018 Just now, Roman said: There's an offset in the ECU, and you set it up with a timing light. You dont need to have the angle exactly right. right. Thanks for that. It just sounds so logical to do it with a timing light. Quote Link to comment Share on other sites More sharing options...
kws Posted February 3, 2018 Share Posted February 3, 2018 1 hour ago, ajg193 said: Distributor drives pump. I'll cry if no distributor. One crank wheel + sensor = far cheaper than coil packs Man, coil packs are cheap. Just grab one from a subaru or VW at pick a part and then you have a sweet setup. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 3, 2018 Share Posted February 3, 2018 9 hours ago, kws said: Man, coil packs are cheap. Just grab one from a subaru or VW at pick a part and then you have a sweet setup. Second hand stuff can GTFO, had too much trouble with second hand stuff breaking. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 3, 2018 Author Share Posted February 3, 2018 Coil packs new don't cost much either. I just used a secondhand pack from a misti. Take a spare on long journeys if you're worried but really.. anything could can fail on your car if you start stressing about perceived reliability. Proper full efficient engine management for the win. 2 Quote Link to comment Share on other sites More sharing options...
kws Posted February 4, 2018 Share Posted February 4, 2018 These are cheap as anything and easy to wire up. They are smart coils so have integrated ignitor. https://www.ebay.com/itm/Ignition-Coil-032905106-032905106B-221603006-221603009-for-VW-Audi-Seat-Skoda/162859466227?hash=item25eb2e3df3:g:vNwAAOSwEVZaYXV2&vxp=mtr Only issue is needing custom leads as the terminals on the coil end are similar to LS1, but not really an issue. 1 Quote Link to comment Share on other sites More sharing options...
Muncie Posted February 4, 2018 Share Posted February 4, 2018 Can anyone recommend an ignition only system for my V-TWIN scooter im switching to mikuni flatslide carby's soon. I have a 12v charging system onboard now to run the fuel pump and other bits and pieces. at present it's just magneto's so no ignition curve and its only setup to run to 3800rpm. Planning to use this engine in a small jetboat eventually so a well setup ignition to match with more revs will be needed. Looking at a Megajolt anyone used this setup? Quote Link to comment Share on other sites More sharing options...
Transom Posted February 5, 2018 Share Posted February 5, 2018 Is megajolt cheap somewhere ? When I looked at ignition only systems they were more expensive than fuel and ignition megasquirt is this a job for speeduino ? Or can you just rig 2 x cdi units onto it ? Quote Link to comment Share on other sites More sharing options...
Testament Posted February 5, 2018 Share Posted February 5, 2018 On 3/02/2018 at 20:56, ajg193 said: Distributor drives pump. I'll cry if no distributor. One crank wheel + sensor = far cheaper than coil packs you only need one crank wheel and sensor to a run wasted spark coil pack setup 1 Quote Link to comment Share on other sites More sharing options...
scooters Posted February 5, 2018 Share Posted February 5, 2018 I did my time with Holden I am bias. But I really do think these coils are good. x1 coil per plug is pritty sweet. LS1 coils are shit hot and to be honest not that much more work than running 1 coil. and inbuilt ignitor. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted February 7, 2018 Share Posted February 7, 2018 On 2/4/2018 at 07:54, ajg193 said: Second hand stuff can GTFO, had too much trouble with second hand stuff breaking. take it from me, i have actualy had my ecu running through my locked dizzy, and even triggered it off the points. it works it also fucking sucks. leave the dizzy there (or chop it down and make it look nice) as the pump needs the drive, but ditch that shit and go to pick a part and rob the coil and ignitor from a subi imprezza. wasted spark setup in one coilpack. 2nd hand is fine, just check the odo and make sure it hasnt done 500,000kms currently i have a trigger wheel hidden inside my dizzy, it works fine, but i am going to switch to a proper crank trigger, as precise timing is more crucial with un intercooled boost! 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 7, 2018 Share Posted February 7, 2018 On 03/02/2018 at 20:56, ajg193 said: Distributor drives pump. I'll cry if no distributor. One crank wheel + sensor = far cheaper than coil packs Fit coilpacks and have a crywank. Your engine's efficiency and tunability will thank you. 2 Quote Link to comment Share on other sites More sharing options...
NickJ Posted February 9, 2018 Share Posted February 9, 2018 We can forgive you for narrow tyres and not bowing to peer pressure on cut springs, but I get the feeling after a full page voting down the distributor you better follow the pack on this one 2 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 9, 2018 Share Posted February 9, 2018 Nah bugger off kewnt. I'll just keep it how it is for about 10 years. I'd probably never save enough fuel to financially justify ecu controlled ignition. Will be more of a "I'm bored, I have nothing else to do on anything. I may as well do something like that to appease people" thing. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 9, 2018 Share Posted February 9, 2018 Dude, it'll cost you like $50 to do. If you're not switching to computer controlled ignition you might as well stick with carbs. 2 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 9, 2018 Share Posted February 9, 2018 A cheaper option than the BIP373 for additional ignition drivers for those of you adding to a MS / whatever else, although you do have to buy 5. https://nz.rs-online.com/mobile/p/igbt-transistors/8648899/ Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 9, 2018 Share Posted February 9, 2018 Next thing you'll be saying is I need to run 98 1 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted February 10, 2018 Share Posted February 10, 2018 There is no valid reason for not putting coil packs on it. Either build a concours car and put the carb back on or install modern computer ignition and reap the benefits of an old car with modern reliability. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 10, 2018 Share Posted February 10, 2018 7 hours ago, ajg193 said: Next thing you'll be saying is I need to run 98 On an engine with 6:1 compression? Nah, but you could add a flexfuel sensor and tune for E85 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 10, 2018 Share Posted February 10, 2018 My fuel hoses aren't ethanol rated, or at least two of them aren't. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted February 10, 2018 Share Posted February 10, 2018 30 minutes ago, BlownCorona said: There is no valid reason for not putting coil packs on it. Either build a concours car and put the carb back on or install modern computer ignition and reap the benefits of an old car with modern reliability. Well it has electronic ignition, so there shouldn't really be any issue with reliability. 1 Quote Link to comment Share on other sites More sharing options...
