63Ragtop
1963 VW Beetle:Ragtop Resto.
156 posts in this topic
Now wiring is something I know nothing about, yet.
what I do know is this is how I got the new loom from the back of the car, to the front.
it was not easy, there is a tight spot somewhere up above the rear seat area, I used alot of masking tape, duct tape and vaseline to get that sucker up to the interior light and snap! went the old washing line I was using to pull it though.
Luckily I had run another wire for future rev counting, I actually ended up pulling the loom out of the interior light hole,use the loom its self to pull it though the tight spot, re-tapeing it to the line and then pull it though the A pillar.
:roll: :roll:
look how clean that speedo it!!!
engine hole.
need to clean these up.
5 people like this
Share this post
Link to post
Got these.
and the grill mesh
dipped next door, gave the mesh a lick of same grey I used on the pan parts.
rear seat bolts, the ODC is real.
yes I cleaned the inside of the trims, :oops: :lol:
flash shows it up, it actually pretty subtle.
my 67's old gas gauge.
cleaned up well, shame it doesn't do much!
steering column cleaned up.
painted the bottom as it was very rusty.
also sanded and paint the column tube and indicator arm gloss black, plus the other bits and bobs gray also.
very happy, been wanting to do that for years, even before I took it off the road.
more stainless buttom head hex bolts.
9 people like this
Share this post
Link to post
forgot how tiny it is! I can stand at the front and reach the windscreen!
Honda is allowed back in the shed(can fit back in)
can't wait to get some weight in it and correct the stance.
1 person likes this
Share this post
Link to post
wait wait, an actual update as well!
box fresh out the acid.
and new starter motor, 2 speed wiper switch and many small things, fresh out the metric nut.
6 people like this
Share this post
Link to post
all these small things take some much time.
details details details. cleaned up door swtiches.
stuck foam stuff under the tank.
front end looking nearly complete!
this is the problem with my old 67 fuel sender, if It's any where near full it will leak and ruin any new paint. :cry:
any suggestions on how to fix this small but important issue, would be great, or should I give up and convert to the electric gauge as my gauge wire thing is bung as anyway.
Share this post
Link to post
I feel the wiring is going to beat me on this thing, I've got 98% all hooked up and I'm sure correct, but the last few details are tripping me up. things like the wiper motor and switch which is because they are 2speed and from a later car they appear to need a couple extra wires, also the Alternator for the same reasons.
Adding to the confusion is the loom seems to be missing a few small, separate small wires, like the one for the speedo light and one for the flasher unit, both of which I was able to salvage from the old looms.
I'll be happy if anything works and it don't catch on fire!
Also had a frustrating night last night trying to get the door window scrapers in, or rather to stay in! very tight work and my fingertips are sore today, was hoping to have the drivers door finished last night, but by 1am I had to give up!
help!
3 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
