troyzakp60 Posted August 31, 2012 Share Posted August 31, 2012 Hey there i have a 2tgeu which has had a bit of work done to it. Cams, ported out ect. im wanting to know what needs to be done to turbo it. i know i can use 3tgte parts. but what exactly would i be using from a 3t? what is all that needs to be done? and would it be hard to do? im not going to be thrashing it round hard so just run low boost i guess. cheers Quote Link to comment Share on other sites More sharing options...
smokin' joe Posted August 31, 2012 Share Posted August 31, 2012 you need the crank from a 3T/gte and the pistons and turbo from a 3TGTE. the motor will then be an 1800 Twin Cam Turbo but without the stupid twinspark Quote Link to comment Share on other sites More sharing options...
troyzakp60 Posted September 1, 2012 Author Share Posted September 1, 2012 do i need 3tgte loom and ecu? Quote Link to comment Share on other sites More sharing options...
kpr Posted September 1, 2012 Share Posted September 1, 2012 if i were doing it. would leave motor how it is. put turbo setup of choice on it. bigger injectors and link ecu + good tune. pretty much any engine will take some boost, long as its tuned right. unless its an aggressive na setup already 1 Quote Link to comment Share on other sites More sharing options...
NaN Posted September 1, 2012 Share Posted September 1, 2012 do i need 3tgte loom and ecu? if you did that: you will also need. the crank angle sensor, cam sensor, their brackets and cables and shit, the correct o2 sensor, the correct air flow meter for that ecu to understand the volume. loom cradles (it's the plastic shit the carries the loom), the correct water temp sensor for that engine (forms part of fuel calculations) it would be easier just to install a megasquirt or link, but yeah, you can do it off the factory ecu you _really_ need to make sure the firing order on the two engine is the same, if it isnt, find another ecu, I think you'd have alot of trouble if the firing orders are different. It's could be just as simple as changing the leads to the spark plugs, but I doubt it. Quote Link to comment Share on other sites More sharing options...
hillman1 Posted October 30, 2013 Share Posted October 30, 2013 All u need off a 3tgte is exhaust mani and turbo sump and oil feed /return and its all bolt on factory ecu will take about 10psi on standard injectors don't push it pas there without dropping compression or your in for big shit as I found with my supercharged 2tgeu on 15psi Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 30, 2013 Share Posted October 30, 2013 All u need off a 3tgte is exhaust mani and turbo sump and oil feed /return and its all bolt on factory ecu will take about 10psi on standard injectors don't push it pas there without dropping compression or your in for big shit as I found with my supercharged 2tgeu on 15psi Lol playing with fire right there 2 Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted October 31, 2013 Share Posted October 31, 2013 IIRC the 2T and 3Ts had a fuel only computer, with separate ignition control (3Ts had a special one to manage turbo / knock, etc). Only when it got to the 4A/1G era did they do an integrated fuel and ignition ecu. Go for an aftermarket ECU. Quote Link to comment Share on other sites More sharing options...
Marty Posted July 1, 2015 Share Posted July 1, 2015 Planning on doing this what do I need could someone pm me some details no internal mods would be great Quote Link to comment Share on other sites More sharing options...
