kyteler Posted September 19, 2020 Share Posted September 19, 2020 Etch prime first so there's a barrier from moisture against the steel. 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 19, 2020 Author Share Posted September 19, 2020 Cool. There is so many differing opinions on the internet, but keen to have some protection. Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 19, 2020 Share Posted September 19, 2020 I mean, I could be wrong but that's the theory I use. Filler can trap and absorb moisture so I figure protect the steel, filler, sand, respray more epoxy if you rub through then sand and filler prime then sand then top coat 1 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2020 Share Posted September 19, 2020 DO NOT USE ETCH PRIMER 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2020 Share Posted September 19, 2020 You can bog over 2 part epoxy just fine, if you are buying a modern filler like evercoat etc it does not trap moisture and the data sheets say its fine to use on bare metal. Just epoxy prime it after you have done the work don't drag it out and leave metal and filler open to the world for ages. Either filler on bare metal or over epoxy primer, then seal it up with epoxy. If you use any single stage paints I will stab you, rattle cans go in the bin. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2020 Share Posted September 19, 2020 Two part filler will react with single stage etch primer and it will fall off in the future, trust me. 1 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 19, 2020 Author Share Posted September 19, 2020 4 hours ago, AllTorque said: There is so many differing opinions on the internet 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 19, 2020 Share Posted September 19, 2020 19 minutes ago, AllTorque said: Its only a Booack at then end of the day. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2020 Share Posted September 19, 2020 The market and information is all fucked up for the hobbyist car painter. The professional grade manufacturers really don't want you using their shit, you will most likely use it wrong and its kind of a dangerous good. The parts stores can't really fork out 2 part paint to every retard so they sell cans of paint technology from years ago, there is no system, no real data sheets its crap. Add all that up and you have a toilet of information. Go watch what a body restoration guy will use, all 2 part products that we mention on old school twice a week. You can do everything with 2 part epoxy primer, seal metal, seal your bog (under and over) , you can wet coat it, you can brush it on, it doesn't sand very well but you can block out for a top coat on it if you wish. It doesn't have isocyanates like Urethane paint so its not deadly. It is the staple tool in doing any body work on a car. Etch primer is old as fuck, it doesn't seal anything, you do not bog on it. throw it in the bin. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 19, 2020 Share Posted September 19, 2020 Yeah, sorry, I wasn't paying enough attention. I saw etch but I was actually thinking epoxy in my head. Derped it up. 2 Quote Link to comment Share on other sites More sharing options...
Lord Gruntfuttock Posted September 19, 2020 Share Posted September 19, 2020 That's my understanding. 2 pack epoxy on bare steel, sticks like shit to a shovel and seals it, then fillers etc... 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 19, 2020 Author Share Posted September 19, 2020 OK. I will look into 2 pack epoxy, but I don’t have a compressor. Brushing on sounds like a ball ache. Quote Link to comment Share on other sites More sharing options...
tortron Posted September 19, 2020 Share Posted September 19, 2020 most of them are very self leveling 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 19, 2020 Share Posted September 19, 2020 You can roll it on with a nook and cranny roller using the fine felt or sponge cartridges. Got a mate who's in the industry and they do it that way sometimes (when someone else's in the both) comes out pretty good apparently.. 2 Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 19, 2020 Share Posted September 19, 2020 I've brushed it quite a bit on repairs. Less cleanup that using a spray gun. 2 Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 19, 2020 Share Posted September 19, 2020 That's the word... Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 19, 2020 Author Share Posted September 19, 2020 Cheers team. Best place to get some around Welly @Nominal? Quote Link to comment Share on other sites More sharing options...
bmxnz11 Posted September 19, 2020 Share Posted September 19, 2020 +1 for Spencer's advice. That's what I've been doing and have not had any issues yet. Another tip I was told, and have used, is when prepping for bog over epoxy, scratch up the bare metal with an old file or something before applying the epoxy so it gives the metal a rough surface to help the bog bond. It gave me peace of mind if nothing else. Some epoxys you can apply and then bog straight over the next day without any prep between which can be a bonus. 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 19, 2020 Share Posted September 19, 2020 Don’t use parts store filler either get some evercoat. Quote Link to comment Share on other sites More sharing options...
kyteler Posted September 19, 2020 Share Posted September 19, 2020 I use a 3M one, it sands a bit nicer than the Evercoat. Quote Link to comment Share on other sites More sharing options...
