Nominal Posted November 17, 2019 Posted November 17, 2019 55 minutes ago, yetchh said: Yeah it's defo vapour lock at the pump, hooked the feed to the return line and let it run for a couple of minutes. Pump stayed nice and cool but as soon as I plumbed it all back up and ran the car the pump got almost too hot to hold and it started cavitating. Looks like I need a new regulator.. Did you check the flow out of the regulator with it plumbed up? I've wrecked fuel pumps due to a crimped/blocked return line. Quote
yetchh Posted November 18, 2019 Posted November 18, 2019 14 hours ago, Nominal said: Did you check the flow out of the regulator with it plumbed up? I've wrecked fuel pumps due to a crimped/blocked return line. When I plumbed the feed to the return and ran it, it seemed to run fine with no restrictions. I think the regulators not releasing pressure at idle, whether the diaphragm is stuck after all these years I'm not sure.. Might see if I can free it up Quote
RUNAMUCK Posted December 8, 2019 Posted December 8, 2019 A mate who cleaned a tank for me said they used citric acid afterwards to neutralise the caustic. Quote
yetchh Posted December 9, 2019 Posted December 9, 2019 Apparently the detergent is slightly acidic.. So I wasn't too bothered. Quote
RUNAMUCK Posted December 16, 2019 Posted December 16, 2019 I'd defo go digital. A digi one should have the option of lambda. Which seems dumb to cave men like me. But apparently when tuning it gives a better indication of how much a change to pulse width gives to real afr 1 Quote
yetchh Posted December 17, 2019 Posted December 17, 2019 Yeah been reading up on afr kits.. Looks like I'll go with the aem kit over the innovate. Like the idea of lambda with stoich being 1, seems a little bit more metric than afr.. 1 Quote
ajg193 Posted February 16, 2020 Posted February 16, 2020 You say it needs cert, for EFI or for other modifications? Quote
yetchh Posted February 16, 2020 Posted February 16, 2020 If I turbo it it'll need a cert for insurance, efi should be ok 1 Quote
ajg193 Posted February 17, 2020 Posted February 17, 2020 If anyone gives you any trouble for efi you can always visit good engineering ltd and I'll write up a report for you 3 Quote
yetchh Posted February 17, 2020 Posted February 17, 2020 Hah cheers bro.. should be ok, my wof guys are pretty good. Plus it's the same motor, just better fuel delivery... Quote
RUNAMUCK Posted February 18, 2020 Posted February 18, 2020 I saw this puppy p outside the wof place yesterday when I drove past. 3 Quote
maxted Posted February 29, 2020 Posted February 29, 2020 Haha whoops!! Another three hours of ringing out the old MA coming up 1 Quote
yetchh Posted March 1, 2020 Posted March 1, 2020 Bro I can't stay out of it.. Goes sooooo much nicer than the shitter carb. At least 5 times now have I driven it, adjusted something then not saved it at the end.. Store is one button click away, need to put a postit note on the steering wheel to remind me. 3 Quote
ajg193 Posted April 23, 2020 Posted April 23, 2020 Hey @yetchh just taking a closer look at your pics for your EFI conversion. It looks like you are using Codan Automotive Fuel Hose (WP 12 BAR) for your setup. If this hose is on the high pressure side it will fail a cert (which the car needs as of April 1st.. ) as this hose isn't technically EFI rated. It's SAE J30R6, needs to be J30R9. The J30R6 actually doesn't cope too well with the heat in your engine bay and can go a bit hard and start cracking over time. Basically, Supercheap Auto sells shitdick hose that you'd expect to be fine for EFI but legally isn't. 1 Quote
yetchh Posted April 23, 2020 Posted April 23, 2020 Yeah, they had nothing that specifically said efi hose, just high pressure fuel line.. Cheers for the heads up.. 1 Quote
ajg193 Posted April 23, 2020 Posted April 23, 2020 I got some Dayco stuff from BNT. I think it came out to about $19 a metre or something at trade price Quote
yoeddynz Posted August 28 Posted August 28 Looks like you dodged a bullet 🤔😁 I'll put the lid back on my tin of bridging filler. 1 Quote
yetchh Posted August 29 Posted August 29 I've yet to have a proper poke around but fingers crossed.. I still might get you to do a door repair Quote
