jtkp61 Posted May 8, 2012 Share Posted May 8, 2012 This is my Suzuki Ma50, also called a Suzuki Selpet. Bought it earlier on in the year, a friend of mine (fliboi) has rebuilt the engine for me - just needs to get wired up. I am unsure of what colour to paint it as of yet. I am looking at maybe going red? I am actually having trouble finding out what spark plug I need, does anyone know? Found one but the thread is too long - would it still work if we used washers or similar to space it up? Does anyone know anyone who has one of these? Would be keen to find out how many of the same bikes are out there. I will get some better photos on the weekend of it. Quote Link to comment Share on other sites More sharing options...
cubastreet Posted May 8, 2012 Share Posted May 8, 2012 Nah get a new plug, they're like $6 from repco. You can google spark plug codes to see what they mean. Here's NGK http://www.sparkplugs.co.uk/pages/techn ... g-code.htm If the thread diameter is 14mm and your current thread length is 3/4" (just guessing, this is common, measure before you try) I would guess something like a NGK B6HS might suit. 6 is a good heat range to start with. If the plug fouls alot get a hotter plug (B5HS) if it burns away get a cooler plug (B7HS) Paint looks good as is. Quote Link to comment Share on other sites More sharing options...
KIRK Posted May 8, 2012 Share Posted May 8, 2012 try looking on japanese ngk or denso spark plug seach machines(choose japan as your region) they seem to show bikes that are not on the usa/global sites. problem is the seaches come back in a mix of japanese and fucked up english edit: http://www.denso.co.jp/cgi-bin/plug/mcp ... c=50&FF=30 if your bike isn't on there then probably one of those bikes has the same engine anyway so yeh. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 8, 2012 Share Posted May 8, 2012 we tried the b6hs from my v50 and i hit the piston, tried the plug from my weedeater and even that hit the piston. this bike must have a crazy compression ratio cause the compression chamber is fucking tiny! but will try what you suggested. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 8, 2012 Share Posted May 8, 2012 Would a Champion CJ8 fit? They are very shallow.. But are only 12mm thread - I should shutup.. B6S - looks more appropriate with a 14mm thread.... Quote Link to comment Share on other sites More sharing options...
KIRK Posted May 8, 2012 Share Posted May 8, 2012 cj8 is 14mm, kaykaykernal. edit: the cJ stands for 14mm. In ngk the first letter ie B stands for 14mm. i think you may be geting confused with different plug brands codes. take you head to a lawnmowershop they will have something that will work Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 8, 2012 Share Posted May 8, 2012 Boom cheers SecksyKirk- I thought I recalled the CJ8 being 14mm but when I (stupidly) cross referenced a Champion to the NGK plug chart it looked like I had ballsed up - hence I put up B6S as a better option.. Quote Link to comment Share on other sites More sharing options...
KIRK Posted May 8, 2012 Share Posted May 8, 2012 the weedeater plug may of been a cj7 which does have a bit longer reach than the cj8. threaded bit is same length tho. edit: i bet that b6s is the plug to try tho. I recockon a flathead lawnmower plug would fit good like a b4lm. Might be a bit hot tho...im running a b2lm in my tecumseh twostroke velobike. Hot as can be haha Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 9, 2012 Share Posted May 9, 2012 the good thing about working at supecheap is that we can come in and turn our stock of plugs upside down, we also came to the conclusion and purchased a b6s. its shallow as hell and should be the right heat plug. weedeater was a cj7 for what its worth. /i should stop stealing jacks thunder Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted May 9, 2012 Author Share Posted May 9, 2012 Thanks for your help guys, what Josh (fliboi) said pretty much. Sussed out that the B6S should ideally be the right size. Hopefully getting it wired up next few weeks and ideally should be on the road! Can't wait. Anybody ever seen one of these bikes the same before? keen to how many there are in the country. cubastreet- The paint looks alot better in the photos is peeling and really rough in person. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 9, 2012 Share Posted May 9, 2012 Boyle Kawasaki on Adelaide road have one on display, and are very helpfull if you get them when they have time to chat/ not a weekend. I know they have ridden a few similar bikes around the south island on missions Wonder if motor is same as my Suzuki F50 could check its plug Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted May 9, 2012 Author Share Posted May 9, 2012 Nice! Cheers mate might give them a ring - that's in Wellington I think? I am in Christchurch. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted May 9, 2012 Share Posted May 9, 2012 Yup in Wellington Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 10, 2012 Share Posted May 10, 2012 The f50 will have a different engine, the ma50 is a sweet 4spd with manual clutch. Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted May 11, 2012 Author Share Posted May 11, 2012 Yea good point there Josh - however it may have the same plug? Not too sure, but pretty sure the one we have now is sweet. Quote Link to comment Share on other sites More sharing options...
KIRK Posted May 11, 2012 Share Posted May 11, 2012 pretty much every old bike runs a b6, b7 or b8 so you wont be far off Quote Link to comment Share on other sites More sharing options...
jtkp61 Posted May 11, 2012 Author Share Posted May 11, 2012 The b6s seems ideal should be fine. Quote Link to comment Share on other sites More sharing options...
cubastreet Posted May 14, 2012 Share Posted May 14, 2012 should be fine. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 14, 2012 Share Posted May 14, 2012 we have governersam coming over this saturday to give us a hand with the wireing. should be all go from there Quote Link to comment Share on other sites More sharing options...
