EURON8's Lada 2103
EURON8
  • Replies 363
I was getting ready for a long time and finally I can make this post. It is dedicated entirely to rare spare parts and honors over the years.
In 2103 there were 3 of so-called series. The first is the rarest and the smallest (all were released 7500) 72 to 73 years. The main difference between them is the front panel of the slots under the air ducts.
The second generation were produced from 73 to 74 years. The main difference was the front panel with a plurality of slots, so-called float
Finally, the most common model, the so-called third series. Model year 1975-1984. The main feature - two big "nose"
There is another very rare item that I've seen a few times. It is native to the muffler in 2103. It has a rectangular tip.
Early-type tachometer. 1972.
Chrome grille on the rear side of the rack. They were set up in 1976
Sidelights production factory "Red October"
Lets proceed :
Floor the gas pedal (until 1974)
 Early type instrument cluster
Lights production of Czechoslovakia
 Early type rear bash ( very rare )
The ceiling handle driver (until 1973 )
Oil carter ventilation filter ( until 1976 )
And body colors :
Corrida 165 (1974-1987)
 Cornflower 480 (1975-1978)
 Light green 329 (1979-1982)
 Banana
 Spain-red 115 (1973-1976)
Diplomat 456
 Sea wave
 Cherry red  127
 Lemon
How do you make Lada really low?
  The answer to this question is quite simple.
  The first way - the easiest. Just cut off a couple of turns of the springs and put the rubber below.
Our guys usually put rubber from Daewoo Matiz, it size 155/65, thus permitted to several problems at once - it does not touch the wheel arches, and the car is lower by a couple of inches
But one thing needs to be done immediately - adjustable Panhard bar. Because when understating bridge leads to the right. When a radical understatement need to digest the propeller shaft tunnel, as it will hit the body.
  Just do not forget that with the front levers will need to cut the excess metal (just to avoid its contact with the body). Later will be photo
Inspiration time .VG told me that this Lada his favorite. For some reason I just now remembered that he had seen and sat in it. The truth was that way back in 2011. Unfortunately it is already sold, probably already a year and a half. I really like the 2103.
This is my photo . Year 2011 , Uman Ukraine .
Panel and paint.
Full suspension revamp for more slam.
Immediate future however. Drive and enjoy / mild tidy up of areas
Suspension will be built on a jig using some spares I have.
But that's all ages away.
Ahahaha sweet memories!
My grandad used to own a veritable fleet of ladas (3!) in the UK in the very early 80s - 2 sedans and one wagoon.
The wagoon was the dog walking beast and the others were generally in constant states of pulled-apartness.
