Eunos Roadster of Initial D stance.
Furai
So I havent updated in quite a while, been fairly busy.
So heres a quick run down.
Smashed a door at Hampton
Crashed into a bank at a hill climb -
Smashed another door after a drunk lady hit my car while it was parked and I was trying to get in it.
Went to Dunedin and just missed out on qualifying
Pulled my engine out and made a new bottom end
So right now the engine is finished, run in and tuned.
Heres the results which Im quite happy with, and thats at the wheels
  • Replies 458
  • 4 weeks later...
  • 1 year later...
On 20/02/2017 at 21:45, 4dori said:
That was a pretty big hit on the hill climb. What was the damage? New engine build looks awesome, looking forward to seeing some vids of it sliding.
Just a broken wheel, couple dents and a bent shock not too bad.
Have been super lazy with up dates but got her all running, tuned and Certed.
36781659_10216630617584749_7372898455548
36912968_10216650554643163_5279149637310
Heres dyno graph, sadly no VVT and the exhaust I made is pretty rubbish.
Vid of it drifting for the first time
So bit of work to do as I snapped the clutch slave, the alignment needs changing and I need to drive better. But slowly getting there
13 hours ago, 4dori said:
  1. So good man! That new engine will be a force with the VVT. How does it feel compared to old?
Yeah should be decent, it pulls hard and smooth but doesnt feel punchy like the 1.6. mid range is a bit flat but heaps of torque. Weight drop is about 40kg over the whole car so nearly sub 900kg and the front being lighter makes it a bit more understeery but the lack of front cambe makes the steering heavy
8 hours ago, Truenotch said:
That was a decent hit on the hillclimb!
I've done similar in the past - mucked up the corner before, thought I'd saved it, threw it down a bank almost instantly.
Glad to see there wasn't too much damage :) .
Haha yeah was a bit of a dull moment on my part but fairly easy fix and I drove it home as well as did another run that day
