Johns Yamaha V50
johnnyfive
Oook, so I bought this off a friends brother.
1978 V50, 3 speed, 'AUTOLUBE', mental front forks, little bit rough, but with some lovin should suffice for chortling around.
Is currently unregistered, and looks to have been registered as a motorbike in its past sometime, so will try re-reg as a scooter perhaps, will see what I can suss.
Also, what is this shaft with collar on it on LH engine cover, it has two positions it can slide to/be fixed into, but doesn't appear to do anything in either, I was hoping it was going to be for 'high-ratio' or something, but alas, it appears to do nothing.
I'm unsure what I want to do with it, gonna try tinker round a bit and get it running better / going faster than 60, and go from there.
Seems to run really smooth and quiet, but has a slight flat spot (or just runs out of power?) towards top of RPM, and gets stuck at 60. Shocks no longer absorb shocks, otherwise seems ok though.
Start chopping so you can go from this
to this
Chopped bars,
chopped seat,
bobbed,
hard tail,
painted wheels and engine,
new exhaust,
new front tyre.
Has a new expansion chamber that actually works now, a bigger piston and higher compression.
Your hitting 65 standard imagine the posibiltys with some mods.
Mine struggled to 55 now it hits 70 and runs out of gearing.
