M_C's '69 Escort V6 Coupe
M_C
  • Replies 231
sorry about that haha. where do you live just out of curiousity?
No worries, I was expecting it to be a particular style of Hiace...
I am in Eastern Bays Auckland and about to enjoy rainy day traffic getting home.
Looking at the Hulix codes the work van has a matching 8" G series with 4.1 ratio. Hmmmmm would fit nicley in the Escort.
Ok, that doesnt look right to me,
- you could re-design the brake calliper mount out of much thicker steel, say 14mm, get it to saddle (at say 8-10mm thick) and then step outward from strut side of the mount, loose the nut bolt arrangement, and tap the bracket with a thread resolving all the problems in one go.
- that rubber bush will die pretty fast.
- you can move the hub outwards, by adding spacers on the underside of the inner bearing race, a machined down old bearing race would be perfect for that.
- I do wonder though, if going to rose joints for the steering arms might resolve that issue, easier, cheaper, and better.
What Russell says - so unless you plan on getting the disk red hot then the heat won't be enough to upset the rubber.
Being as its an Escort with an Essex V6 in it - I'm going to say it won't - Cologne V6 may be a different case..
By the way thats not what I would call close - close is the thickness of a playing card...
I really would have thought that rubber would be a problem; really good information to know because it totally runs counter intuitive. And I'm pretty sure thats going to come up with my project.
Good news I don't need to pull it all apart again. Surprising that such a small gap has been OK on Low N Slow, I was not expecting that asnwer. Was expecting more along the lines of the awesome power of the mighty essex will soon wilt the rubber resulting in a quick armco embrace.
Going to have to pull it apart again at some stage to paint the brake brackets so will skim a little off them and the spacer then.
Cheers
Cheers mate, found that one. Looks like a standard type 9 for 1600 for 2L. From memory the 3L ones have strengthened input bearings or they get lunched quickly. Current plan is to pull the Zodiac 4spd out and see what's going on. If toy money funds allow I have a line on a rebuilt celica 5spd with correct bellhousing. Hmmmmmmmm nice 5spd...
